hey everyone im new to the skyline forums
my names sarsha from brissy northside here is my r32 skyline im interested in meeting other skyline owners and going on some cruises or skid pan/ track days
Edited by MIS532
https://www.sau.com.au/forums/topic/400529-hi-everyone-im-new-to-the-forum/
Cruise: look out for one soon, end of july at the latest. There's also a drag day on this weekend if you're into that, check out the events section
skid pan: maybe.
Indicators: do want, how much did that set set you back?
Hey mis532 and everyone. Been a member for ages but never really written anything. Drive the silver/grey r34 sedan in and around Robina and into surfers most days. Sorry if I cut you out in traffic but remember - keep left unless ya overtaking :)
  • 3 weeks later...
    • Surely the cam timing is set to something stupid at low RPM?
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
