Hi All,
I've got a full rebuilt RB26 block with a completely balanced crank from a R34 GT-R, CP pistons 87mm, Eagle Rods with ARP rod bolts fitted a Tomei Oil Restrictor on it too for sale. Comes with all new welsh plugs and has been painted to look new.
Engine has made 441awkw @ 9000rpm without any problems. Has been about 5000km on it since the rebuild. Reason for selling is i've upgraded to RB30 and no longer need this block. The block has been revved to 9000rpm each time without any problems at all. Good for someone with a set of -5s and want to push it to the limits. Willing to send interstate via courier.
I've got all the pictures of the rebuild and the block now for those who are interested please send me a PM. Price is $2750 ono.
Also have a pair of HKS Dump pipes also. These have about 10000km on life on them and is in perfect condition. $320ono
Cheers,
Gordon
Edited by destrukshn
I just recently got burnt on buying a block from interstate so want to make sure this is what it is advertised as. Can the workshop provide the receipts for the part bought for the rebuild? Also what oil pump is it running?
Can you pm me pics of the build?
Thanks
Fair enough mate. The parts were bought from the US by me and as I said my dad built it himself so I cant provide you any receipts. I can send you all our rebuild pictures though to see if you're happy with it from the original packages of what was bought and the crank balanced etc. I kept a rebuild diary so I have pictures of everything. It is running a Tomei oil pump which isnt included in the sale of the block.
PM your email and will send you pictures of the build.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
