Hi Guys!
Up for sale is my LS1 Silvia track car. It breaks my heart to sell it but due to personal and financial reasons I can no longer justify keeping it. I have been building it slowly over the past 2 years, and a lot of effort and money has gone into this project.
Over 20k has been spent on it over the years, including engine, shell, conversion parts and much much more.
Includes the following:
S13 Shell:
- BN body kit
- Full seam welded
- Custom respray, top half candy pink, bottom is black with gold sparkle (easy to fix with track damage)
Conversion:
- Daft Inovations conversion kit
- Daft long tube headers
- Summit racing mini starter
- Custom lines
Engine:
- HSV VY clubsport 280KW motor
- 6 speed gearbox
- Custom long tube headers
- Mafless tune
- twin fuel pumps
- Surge tank
- Fuel cell
- Monster LS1 Drift button Clutch
- Oil cooler
- Alloy radiator
- twin thermo fans
Suspension/Brakes:
- HSD front coilovers
- HKS rear coilovers
- NON-Hicas rear subframe
- R33 Front brakes and rotors
- R32 Rear brakes and rotors
- 5 Stud conversion Front and rear
Drive:
- Custom drive shaft (2 piece)
- Skyline R32 rear Diff (locked)
- Skyline R32 rear 5 bolt drive shafts (stronger and thicker then s13)
Interior:
- Custom stand alone engine loom
- Custom body loom (stripped back to bare essentials, massive weight saving)
- Monster tacho
- Autometer gauges
- Roll cage, bolt in half cage
- Stainless steel rear parcel shelf divider/fire wall (block of fuel cell in the rear)
- Nismo bucket seat
There is a lot more done to this car that has not been mentioned, to many parts and hours have gone into this car to be able to list them all.
Price: $15,000 as is Will include all spares and extras
IF you have any questions regarding SALE of vehicle (don't want calls asking about help on your conversion) please don't hesitate to call.
0400 200 997 (Paul)
https://www.sau.com.au/forums/topic/400597-ls1-s13-silvia-trackdrift-project/
Few questions been receiving about the car:
- The shell does have registrable tags.
- The diff is welded (has been pulled apart professionally and bearing inspected)
- The wheels are VOLK GT-C 17x9 +19
- Will ship interstate at buyers expense
Thanks.
No reasonable offer will be refused. Needs to go. Cheers.
  • 3 weeks later...
I am interested in buying complete if the price was adjusted to something more reasonable.
I am sure you have put a lot of hard work into this but the reality is that it isnt worth what the parts cost you.
Pm me if you are interested in selling.
  • 1 month later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
