Hey all My car has just given up on life today and I really need some help to hopefully get close to the cause of it...
I drove it yesterday and it was fine.
I drove it for 15 mins to the mall today and it spewed its guts out in the car park... Its Brown murky water that was coming out from the rear of the engine inlet side, (My coolant was pretty green last time I checked about a week or so ago)
I proceeded to head home hoping it wouldn't overheat much as I live fairly close, but within 5 mins it got up to 110 deg
I quickly pulled into BP and it was sizzling and steaming HEAPS where all the heater hoses are under the inlet manifold next to the block. I then opened the radiator.... Empty... Filled it up with cold water.
Temp gauge said 40 deg...so I started on my way home. 1 minute down the road the temp gauge went up to 110 deg, so I pulled over again. Same thing, sizzling and steaming under the manifold.
But this is the catch, the radiator was still really cold, the top hose was hot, and the bottom hose was cold....
Im hoping its a heater hose seal broken under the pressure and leaking out there, rather than the head gasket, and im guessing my thermostat is stuffed??
Does anyone have any suggestions for the cause?
Also I live in Glen Iris, Melbourne, does anyone know and good skyline mechanics sort of near me.. I know RacePace is really good and Chris is pretty onto it, but Bays water is way to far in this situation...
Thanks guys :)
https://www.sau.com.au/forums/topic/400603-need-some-help-and-suggestions/
one hose will always be hotter than the other as one hose is have cooled coolant flow through it and one has coolant fresh out of the engine. and given that there is a leak in the system, that will make the problem worse. also if your radiator is somewhat blocked (not totally blocked, but not flowing like a new one, which is a common problem on older cars) then that will make the radiator feel colder than it should
another possible issue is that your water pump is worn out
Water pump was also another possibility that just came to mind also, so maybe that needs looking at, I wish there was a way to test it. Its just weird because the temps rarely go above 76 deg on ecu and its always run fine, then it just did this out of the blue. Water pumps dont just work 1 day and not the next do they?
When I mention the hose and radiator were cold, I mean like chilled cold.. definitely not normal.
Thanks for the reply
i think the first thing is to get the leak sorted and then see what temps do. a leak in the cooling system will cause temps to skyrocket. for example, i've seen plenty of overheating issues caused simply by a dodgy radiator cap.
Yep. Fill up cooling system with water and pressure test, check for leaks. If no leaks are present and it holds pressure then remove thermostat and check opening temp. Replace if necessary.
Retry bleeding cooling system and try again
Today I disconnected the radiator and hoses and flushed it and the block out with heaps of water. Fitted a new thermostat. then filled it all up again.
It bubbled a little but it didn't look anything out of the ordinary. at about 90 deg it started to overflow as it would. so I put the cap on and went for a quick drive around my apartment
It didn't overheat once pressurised on the drive, It got to 90-92 deg (using water) Once home I noticed a constant dribble coming down the gearbox from above the starter motor. I cant see the actual place it was leaking from tho.
Good news is the water pump still works and it was clean water leaking not oily water as suspected earlier, nor was the radiator bubbling or dipstick with any residue. bad news is I cannot see the leak so the manifold will need to come off, Im suspecting a heater hose.
It looks like a bit of a mish to get it off and I don't have too many tools here to even consider the task ahead. Is there anyone recommended for skyline work? I dont want to take it to just any mechanic.
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
