I put a pod on mine. Still need to redo the setup with the new pod and intake pipe, but I found an increased AFM voltage on the Informeter, which I interpreted as increased airflow compared to the Blitz panel in the stock box with the inspection cover removed. Intake temps were about the same, but I didn't check that as closely.
Considering the pod was old, and fitting was intended as an experiment to see if I could liberate enough room for a catch can, I think with a new pod (which I've got in the shed) and an intake setup to do it justice I'd be able to see noticeable gains.
  • Replies 65
Lol. Back in your box. :)
I compared a stock paper panel and a pod just before, the paper one looks like it would have twice the surface area. Does anyone have an old pod they can cut up in the name of science? I will measure the panel filter.
I will humour you and give you some maths to work out.
I just measured the R2C pod that will be going on the Nismo intake I have for my Stagea (when I finally get it lol).
Okay the closed end diameter of the filter medium is 130mm. Open end diameter is 150mm. The length of the filter medium between the two ends is 140mm. There are 44 folds in the filter medium each of which are 13mm deep.
:geek: right then so to find lateral surface area (S) we need to use S = Pi(r+R)s
Closed end radius ( r ) = 65mm
Outlet end radius ( R ) = 75mm
Slant height ( S ) = 140mm
S = 3.1416 (140) 140
S = 61575 (rounded).
This is for a solid surface and obviously doesn't take into account the folds.
I presume your panel filter will be width x height? I don't have a panel filter lying around so I'll go off the K&N specs on their site which may or may not include the frame of the filter. http://www.knfilters...?Prod=33-2031-2
279mm x 167mm = 46593 not including folds.
So if both were solid, the R2C pod has almost 1.5x the surface area of the oem panel filter.
Feel free to work out the element size if you include the folds :)
And just because I went all geek just then, here's something to even it up.
Edited by iamhe77
The panel filter I have here has 84 folds at around 1 inch deep, multiply that by 2 (as I was only counting the tip of the fold and each one has two sides), it should come to 169 inches long approximately. That is a massive surface area.
I like your anti-geek pics Cam but I don't think it helps you case much at all. :P
lol, that would be the factory paper panel filter. So tell me again why you ditched it years ago for a K&N and more recently a Blitz?
Something about restricting flow?
Edited by iamhe77
+1 ^^^
I may have to test all this out on the dyno as I was under the impression taking the panel out and running without a filter would make very little power difference. Perhaps there is merit in testing a few options including the paper one...
lolz.
So your putting a POD to suck up hot air or air from the front bar(look out for puddles and mud) of an N/A 3.5 standard motor that already has a standard airbox that is more than good!
lol attack at will Craig with your narrow mindedness.
My car isn't coming with an airbox.
Narrow??
I've had cars with Proper CAI, POD's, Panel filter setup's and Standard setup.
My Giocattolo had POD's when I got it.......pity they made a lot less HP on the dyno because they sounded great!.......Panel filter made more HP btw!.
BTW - I know of a standard PNM35 airbox for sale atm! or you can talk to him!
Edited by Jetwreck
Narrow??
You make me laugh Craig, so fired up over this.
You wanted to know surface area so I gave you some unbiased maths.
Since you are directing at me:
No, I don't want the standard airbox as I already have the intake sitting in my garage.
The reason I went for a pod is because R2C don't make panel filters. From what I have seen their filter medium is the most efficient, best filtering, re-usable, dry filter on the market (at least that I could find).
Edited by iamhe77
How am I fired up! I couldn't give a shit what you or others run....lolz
I'm actually laughing at you thinking a pod is better that a proper CIA system....or better that a standard airbox on a m35.
I'll let you believe your own bs though! :P
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
