Lolz....this cracks me up.
Fyi.....the fastest group a r32's in the world use.....wait for it.....a panel filter in an airbox!
Sucking hot air from the engine bay is for noobs!
Yeah, yeah; what would you know about fast R32's anyway... :whistling:
Never got the whole pod filter thing...
  • Replies 65
Remind me, is that beautiful shiny airbox you refer to a stock R32 item?
lol, my point is that they don't use the standard "retail/consumer" R32 airbox because it would be too restrictive and instead designed that lovely air box which uses two panel filters if my very hazy memory serves me correctly.
In the end, more air + more fuel = more powah, so why the hate on a proper pod set up?
if it sucks from the engine bay it's shit!!!!! end of story....no contest..........sounds good and goes shit!
Not saying that all setups are bad......of cause a well set up CAI will work but if you go to all that hassle why not do it properly? Surface area will always win so why go with a POD???? You don't see POD's on GT500, GT1, GT3, V8SC........I wonder why that is?
BTW.....Dad's old road/race going R32GTR was a little of 600hp at the wheels.....standard airbox!....ran 11.1's all day hot or cold! The guy's with POD's were all inconsistent!
Agree 100%
POD designs generally have a larger surface area than a panel filter, that said it also comes down to the efficiency of the filter medium.
Definitely nothing against an airbox, nor a properly set up pod.
I don't know where you got that info Cam, which pods do you think magically have a larger surface area? I'm happy to prove you wrong, just bring a pod to me before tomorrow night and we can test it on the dyno while its being tuned.
His talking about the circumference of it vs the flat dimensions.
With your bonnet open and the fan on you "might" make more HP..."might"! Bonnet closed and no fan :no:
If you take the filter apart and straighten out the filter medium in both the pod design and the panel design, you'll find that generally the pod will have a larger amount of filter medium, thus larger surface area.
I'd be interested to test out a decent pod on your car actually, but you'd have to extend the intake piping to either in front of the radiator or down to the area in front of the passenger front wheel. As it is, I do actually have such a pod sitting in my garage....
there is a pretty easy solution to this. Why don't we hook up my laptop, and just read the intake temps on two different cars- one with Pod, one with Airbox.
Just need some test subjects in sydney!
I'm sure Craig won't mind being the stock airbox car.
Who got a pod?
(would use my car, by the AFM isn't in the stock position, so it won't be an accurate reflection really)
Lol. Back in your box. :)
I compared a stock paper panel and a pod just before, the paper one looks like it would have twice the surface area. Does anyone have an old pod they can cut up in the name of science? I will measure the panel filter.
How about they just measure a couple of diameters or circumferences, Im sure we can just do some maths :P
Look what you've started now cam!!!!
Anyone ever seen a pod shaped vacuum cleaner that's any good? Or are we all using the flat type.....might go and check with the wife to see what we have!
Pretty sure they all feed the same sized pipe (unless it has been changed) so we could dick schwing for ever and a day I reckon two parts of bugger all difference if there is a reasonable cold air feed to a pod or a panel filter.
Do it or don't do it. It doesn't matter much either way. Sure the quality of the pod/panel comes into it but I am assuming a reasonable quality pod/panel is used.
I changed mine for ease of packaging reasons with aftermarket turbos and so I could exercise my dodgy cold air box fabrication skills. I am under no illusions about whether there is power to be gained or lost at the power levels my cars are reaching.
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
