need some advice ,
would it be good or crap idea to remove the factory baffle plate and run the rear breathers stright to sump for oil drain, and weld 2 x-12 at the front of rocker cover to oil catch can ?
9l sump -
oil catch can drain to sump
i seen this setup on the single cam rb30
thanks gery
https://www.sau.com.au/forums/topic/400639-rb26-baffle-plate-rear-breathers/
Keep the baffles in the stock spot.
I cannot see any advantage to run frontward ones, and turn the rear to the rear go direct to sump. Means you'd have 2 going:
Head -> C/C -> Sump
Head - > Sump
Bad idea. If you are having oil/breathing problems then the solution is not at the end, it's in the motor build and restrictors.
You don't really want to be draining the head - you want to prevent it from filling up in the first place and if you are still to build the motor you can do it right instead of trying to apply bandaids afterwards. Have a read of at least the first few and last few pages of this thread:
http://www.skylinesaustralia.com/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page__hl__sk+oil+control
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
