Yeah the flu sucks Adam - hope you and Krystle get over it quickly!
Yeah the HUGE problem with a cruise is that the organiser of the cruise takes FULL responsibility for EVERYTHING that takes place on the cruise. I know we are not a group of louts, but even if the cops pulled someone over or came to one of the meet spots they would want to speak to who is in charge, check for the appropriate cruise insurance (and yes SAU:SA club cruises have this), etc etc. Sadly it is not as simple as just organising a cruise. Plus if we do it on a weekend afternoon we WILL get a slow car(s) in front of us and you end up doing the most frustrating 60km/h cruise in an 80/100 zone you have ever done. Hence why SAU:SA does dawn cruises, or goes WAY off the beaten track (like our next one in a few weeks is to Victor Harbor and takes some cool roads way out the back of beyond to get to Victor by the long route.)
well said. i forgot to call you about lunch;) and you forgot to call me too. you need a passanger for the victor cruise??
  • Replies 64
There is an association of Z people that I did a cruise with last year - good group of guys. And yes, we should hook something up with them once the weather fines up. I didn't go due to car issues (cracked high flow cat/bent exhaust manifold), but the SAU:SA club cruise on yesterday was rained on all the way to Victor :(
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
