  • Replies 79
See you there Ryan.
Adam, if you want a passenger seat, I will be heading through Ryde about 4ish.
Thanks mate i am going to work instead i have now got to pay for then engine and all the parts thanks anyway i will see everyone on the next one
ready to go! washed and vac'd... what a great looking day out there. If your Stagea is broke, doesnt mean you cant drive the other car and come along.
Craig is a massive fairy. He's upset that my car can keep up with his. (that should do the job... :P)
Lol, are you sure it's Stagea Cruise day?
Normally it's pissing down; and you'd be better off with an ark...
Well, had a great night meeting new faces and old faces, Stuffing my face with pizza, and watching other peoples faces when 11 ( I think) Stageas drive past!
Hope everyone had a enjoyable, and safe trip home.
Good to hear :)
Did you see a row of Foresters coming back from a cruise to the Hunter today?
I was going to join them to go through Wollombi as a Recon for a future SAU cruise but we've had a death in the family and couldn't make it. :(
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
