Who wants an awesome daily that's fun to drive, yet doesn't get you in trouble by the cops because it looks so damn illegal? Not me, it's gonna cost me my license/job lol
I've had it for about 6 months, bought it off my mate who had it as a project. In that time, I've cleaned it up a bit and driven it to and from work (Gladstone Park to Tullamarine Airport).
It has an SR20DET from a Jap-Spec Bluebird SSS, a standard GTiR turbo, a front-mount cooler (painted black so no attention), has DE cams for more lift (apparently), pod filter and an X-Force exhaust. I'm not gonna lie, the thing f**king flies and is a hell of a lot of fun to drive.
Since I bought it off my mate, the gearbox was a bit on the mehh side so I replaced it with a low KM one off an import, along with putting a brand new HD clutch in it while it was already out of the car. It's got an electronic boost controller in it but I'm borrowing it off my cousin at the moment and will return it to him once the car is sold, while the car will have one of those manual "drift" branded boost controllers fitted. It also has a brand new battery and a brand new alternator (higher ampage), both about a month old, and the battery has been professionally relocated to the boot, and GTiR brake setup
On 10PSI, I got 141KW at the wheels, I was told on 13 I'd have between 155-160 at the wheels, but I didn't do the power run on 13PSI.
The car will be sold as is, so no rego or RWC. I'm asking $4,850ono for it. No swaps, need the money at the moment coz I've just bought a shitty old VP commo to get me to work and back while I save for another property.
It does have a bit of a dent if you wonna call it that on the rear driver's side 1/4, I've taken a photo so you can see. It's not the most perfect car, but it's an awesome as f**k daily!
Text or call on 0488-582-587
I'll entertain offers because I'd like it gone ASAP, but nothing stupid
Edited by stawka
https://www.sau.com.au/forums/topic/400691-nissan-pulsar-sss-turbo-conversion/
  • 3 weeks later...
  • 3 weeks later...
No swaps thanks... And I'm not gonna drive it to Adelaide and walk back. You can fly here, or come down yourself... Or I can meet you half way if you deposit the money into my account because I don't want to waste my time and effort for nothing
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
