Nissan Pulsar Sss - Turbo Conversion
Who wants an awesome daily that's fun to drive, yet doesn't get you in trouble by the cops because it looks so damn illegal? Not me, it's gonna cost me my license/job lol
I've had it for about 6 months, bought it off my mate who had it as a project. In that time, I've cleaned it up a bit and driven it to and from work (Gladstone Park to Tullamarine Airport).
It has an SR20DET from a Jap-Spec Bluebird SSS, a standard GTiR turbo, a front-mount cooler (painted black so no attention), has DE cams for more lift (apparently), pod filter and an X-Force exhaust. I'm not gonna lie, the thing f**king flies and is a hell of a lot of fun to drive.
Since I bought it off my mate, the gearbox was a bit on the mehh side so I replaced it with a low KM one off an import, along with putting a brand new HD clutch in it while it was already out of the car. It's got an electronic boost controller in it but I'm borrowing it off my cousin at the moment and will return it to him once the car is sold, while the car will have one of those manual "drift" branded boost controllers fitted. It also has a brand new battery and a brand new alternator (higher ampage), both about a month old, and the battery has been professionally relocated to the boot, and GTiR brake setup
On 10PSI, I got 141KW at the wheels, I was told on 13 I'd have between 155-160 at the wheels, but I didn't do the power run on 13PSI.
The car will be sold as is, so no rego or RWC. I'm asking $4,850ono for it. No swaps, need the money at the moment coz I've just bought a shitty old VP commo to get me to work and back while I save for another property.
It does have a bit of a dent if you wonna call it that on the rear driver's side 1/4, I've taken a photo so you can see. It's not the most perfect car, but it's an awesome as f**k daily!
Text or call on 0488-582-587
I'll entertain offers because I'd like it gone ASAP, but nothing stupid
Edited by stawka
  • 3 weeks later...
  • 3 weeks later...
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
