Dodgy Hole Cut Under Battery Support For Intercooler Pipeing..
hey folks
so today i took all the intercooler, pipeing, hosing and bov's off the car, to reveal that the hole cut under the battery for the intercooler pipeing has been poorly done.
I have been told that on R32 gtr's this hole come stock standard, therfor you cannot be defected for it ??
As the pics show, someone has cut the area out, made the hole slightly bigger/bodgier n then only tac welded the peice back in place, and just slapped paint over it, it probably had 10 MIG tac welds holding it in place.
The car was complied after import and has been roadworthy'd twice once in NSW and once in VIC and this was never noticed.
I have owned the car since it was imported.
The pics were taken before i took a thick 1mm chunk of paint off the whole lot, looks like they just got a paintbrush and slapped paint over the bodgy job. After the paint was all scraped back to the original white paint, you could easily see only maximum of 10 or so tac welds holding the plate in place.
I plan to fix this up, weld the peice back in properly and grind it all back down. By trade im a sheet metal fabricator so fixing this up is easily done.
In the engine bay i was thinking of getting some either 1.6mm or 2mm plate and covering the area around the hole where its allready cut and recutting a new hole in the 2mm sheet, that way it looks neat and is strengthened.
Can anyone tell me if i can be defected for this ? obviously after i start welding im guna need an engineers cert to show its strong and been done properly. But thats only 100% necessary to get the engineers cert if the cops make me do so, correct ? Because ill do a bloody good job and itll be very neat. Hardly noticeable maybe only noticable to a GTR enthusiest..
Whats your opinions about this ? keen to hear others thoughts and opinions on this
cheers
post-58667-0-90622200-1337590758_thumb.jpg post-58667-0-67648800-1337590801_thumb.jpg post-58667-0-12138000-1337590837_thumb.jpg
THIS LAST PIC IS LOOKING FROM IN THE WHEEL WELL. post-58667-0-71537500-1337590944_thumb.jpg
Edited by r32gtrv-spec
gotRICE? - deffintly not a gtst/gtr conversion as behind the right hand headlight where the other intercooler hoses pop thru the chassis is genuine to fit a GTR, not just a dodgy hole cut - IS THERE ANY OTHER WAYS TO TELL IF THE CHASSIS IS FROM A GTST ?
i got no idea why someone has made such a mess with it, all i can assume is perhaps that spot rusted out and/or was replaced poorly with a dodgy cut out peice from another car.. ??
if someone did do a gtst/gtr conversion, the chassis number is for a GTR - im almost tempted to rub back the paint on/around the chassis number, to see if anyone has cut/welded in the area around the chassis number
 Share
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
