Interfacing Turbo Timer With Alarm
kyle_24
 Share
i have just installed my turbo timer and i bought one of those adapters so i didnt need to cut any wires, but my problem is when i switch the car off the engine still runs which is cool until the timer does its thing but when i go to arm the car only the doors lock. anyone know how i can interface the alarm with the timer or anywhere i can go get it done.
any help or ideas would be greatly appreciated
I agree although my skyline has a working interface alarm/ turbo timer. But it was like that, and i never ever use the turbo timer unless i do an occasional track day but turbo times are just annoying, and to many dramas. I would suggest removing turbo timer (Useless function ) unless your smashing your car for long periods of time on the road which we hope your not :/
yeh i know but since i have it i might as well use it. asked a few auto sparkys and got different views. some say u need a module in ur alarm, some say change it to igniton key side, some say chuck a couple of relays in.
  • 3 weeks later...
yep .. piss the timer off..
Hi chris
I've heard this a few times in regards timers and alarms. I'm currently running a timer in my R32 however would like to install an alarm and remote central locking. Is there any way for the timer and alarm to work harmoniously together or is pissing the timer off the best option. If so why? Thanks in advance for your time and knowledge.
(cynical mode )
so you want me to come take your car in the middle of the night ? may as well you have made the 3 basic things a lot easier for me to access..
(/cynical mode)
in all honesty find a unit that has one built in or one that will allow a timer to work with it.
autowatch have them built in and they can be wired accordingly with various countermeasures. ( customers of mine know what this means - send me a PM and I will explain it.)
mongoose will go either way. they have the ability to act as a timer or will work with one IF they are setup correctly.
its more about install than alarm though.
guess my post didnt show up, the guys at an alarm shop replaced the chip inside my alarm allowing a turbo timer to be used with it. no needing to change anything, the chip cost $20-30
 Share
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
