Hey all, I just threw out a couple emails around the place to get a few quotes on superchaging my V35,
Just wondering if any of you have SC'd your V35 or have any recommendations of a good garage from personal experience,
annnnd what Id be looking at for a general quote so I dont get ripped off, Im already guessing around $5500 for the SC but what shud I expect for install/labour + tune etc, maybe around $8000-$9000?
I dunno help me out here,
Cheers guys,
Brenton
https://www.sau.com.au/forums/topic/400745-suggestionshelp-etc-scing-my-v35/
The big issues with supercharging is, that to do it properly, you really need to decompress your motor somewhat, which really means engine out full rebuild. So once you add $5k in rebuild/major service parts, plus removing/reinstalling the engine ($1,000-$2,000), plus labour for rebuild (1,000-$2,000), THEN add on top labour to fit and tune the SC ($3,000-$5,000), it is a pretty expensive exercise, to say the least.
But with 300rwkw it would be all worth it :)
Going to have to disagree with night crawler.
It's not the compression of the motor in itself that is the problem. You have to get the car tuned, therefore all of the timing figures are going to change to be safe for the pressure your running so det isnt an issue.The problem with the stock motor are the connecting rods are weak. However they should not be near their limit with the std pulley on the Hks kit. If you are shooting for big numbers then you will have to rebuild and lower the compression as nightcrawler said. Neither will you get 300kw with a sc kit. Expect off the stock kit 210 to 230kw at the rears depending on how happy the dyno is.
I would be suprised if a shop could do it for 8k. I don't see how when you think about the cost they are going to charge you for engine management as well. Plus you will need supporting mods as well like a shift kit and cooler if auto, brakes if no brembos, and suspension. Myself and a mate have installed a Hks sc on a 350z. You might have already contacted him.
Depends on how much boost you want to run, low boost with 98 RON fuel and you should be ok. (assuming stock injectors can keep up.)
If you want to start running higher boost, then you need reduce your engine compression ratio.. doesn't matter what you do with the timing, if cylinder pressures get too high for the fuel you run, you will get detonation, which will quickly destroy your engine.
I wouldn't recommend stock injectors. They are small, like 310s or 330s or something. On my car they would be 100% duty if i still had them in. You really can only run low boost on the stock block. Put it this way, at 6psi, I have gained bout 70kw at the wheels.
Run 600s or 1000s if you want e85, bigger pump. You need a bigger afm if you go above about 4psi if not going to maf less.
I would suggest you only go as big as you actually need with injectors. If you only need 500cc.. then just get 500cc. The only positive with running anything larger is they will cope with more demand down the track, everything else is a negative, poor economy, poor idle, etc.. under light engine load (which is going to be the majority of the operating conditions), it will be a bit like the ECU trying to measure out exactly 5.25ml of fuel using only a 10L bucket..
There is something called headroom that you need when choosing injectors. You don't want to run them at 95% because when you ask a little more of them ie cooler conditions, or a boost malfunction, they will lean and damage your motor.
Those symptoms might be true with eBay shit high flow injectors, where some one has drilled holes in the bottom. But if your talking about good quality injectors, it's not a problem. My idle is perfect, even with bigger afm and 600s. Really it's not pushing any limits. And you need a good tuner to get the basics spot on to get it perfect.
So therefore proven recipe 600 on pulp, 1000 on e85
When i was looking at doing a SC kit i was going to buy the full kit from HKS, it comes with, ECU plugin, injectors and i think fuel pump its a full bolt on kit dont need to buy anything else for it, but as they guys are saying if u want more then 6 pound boost u need to forge internals and thats about 5k worth including parts and labour in that.
Buying that whole kit is one of the biggest mistakes you could make. Your injectors are just a 7th injector. You have a Hks computer which only 2 or3 people in sydney can tune, and it's hideously expensive to tune. Better off saving the 1g and doing it properly.
Plus by the pics it just looks like a piggyback Fcon iS.
There is a used v35 kit on yahoo Jpn at the moment.
So 1. its ridiculously difficult to just go out and go "hey I want this SC on this car, GO"
and 2. you guys rekon its just better keepin it relatively stock(as in) and grabin a 34GTR ye?
Sounds good T4NK did u seel ur V35 and grab 34GTR or just have both? If I do that option Id have both, Insurance go through the roof though :P
Edited by Haino
Depends on what you are after. if you want a high performance AWD car, with scope for some good power gains without needing to do major internal engine work (unless you want to go silly), then the GT-R is the better option by far. there are heaps of aftermarket options out there, plenty of people who have been down the track of modifying a GT-R and able to offer advice, and you shouldn't have too much trouble finding someone who knows how to tune it for you.
On the other hand, if you want to keep your comfortable daily cruiser, but just want a bit more 'stick', then go the FI route on your V35, just be aware, even mild boots is going to cost you a premium to do it properly.
^^^^ what he said.
On your number one point, no its not hard. Just expect to reach deep into your pockets. If you can do work yourself, and do some research into it, Rather than just taking whatever is in a kit, then it works out much cheaper.
Remember, gtrs have their failings too. You might go get one, and spin a bearing in your first week. Hello 8k basic rebuild.
Cost for cost, once and engine rebuild is taken into account the V will not disgrace itself against a gtr in a straight line. It doesn't have the benefit of awd, but it is also more comfortable and easier to drive IMO. And you'll never end up with oil in the rockers in a vq!
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 馃槀 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
