So as title states. I just recently installed my TS2CD OS Giken. with the recommended sleeve and bearing
Release bearing : Nissan 30502-14601. Release sleeve : Nissan 30501-U0200
Now I went to pull the car out of the garage and moved about 2 inches with the clutch out and the car in gear.
Also i can put the transmission in gear with the car on and the clutch NOT depressed. basically feels like the car is stuck in neutral.
what would you guys recommend?
Slave was bled properly and clutch pedal has right feel to it.
stuck and would like to try some things before i pull the transmission and put a smaller sleeve on.
sounds like clutch is constantly depressed (a bit like you if you have to pull the box out again o-;)
try the adjustment at the top of the pedal, but I wouldn't think it would that much adjustment, but worth a try before you pull the box again..
could be wrong length sleeve?
That is going to be my first attempt when i get some time. The clutch pedal adjustment. I also had the same thought that it couldnt be that much adjustment to make that big of a difference to the clutch itself.
And yes im coming to the conclusion that the clutch sleeve OS Giken has listed on their site is infact to big. Which inturn keeps the pressure plate in a neutral state...
Sigh....
Anyone running this clutch? what sleeve size are you running?
The sleeve OS recommended was the 16mm
I think im going to try the 12mm or 14mm... any suggestions?
if anyone will run into the same problem and comes across this thread hear are bearing sizes ad part#
30501-A3800 12mm, 30501-N1601 14mm, 30501-U0200 16mm, 30501-S0200 18mm, 30501-B6000 20mm, 30501-S0160 22mm, 30501-K0404 24mm, 30501-K0510 26mm, 30501-N1600 28mm, 30501-N8400 30mm
if its only 4mm, it might be at the end of its adjustment but, I would think you should be able to get it to engage with the pedal adjusted to the max and foot to the floor, if not its more than that..
another option; instead of taking box out etc get a threaded rod for your slave, not sure who does them.
but my car has one because the previous owner had alot of trouble getting an OSGiken triple plate ( the name escapes me atm) to work properly, so with the threaded rod you can easily move where the folk sits..
Also get someone to sit in the car and push the clutch peddle while you watch the slave under the car to make sure you are getting enough travel in the folk..
clutchs??
Slave cylinder has been bottomed out and it's disengaging the clutch. The rod needs to be shorter and just how much shorter will become clear once you pull the slave cylinder off which won't be easy seeing as it's under pressure from the clutch.
Once you get it off push the cylinder with the rod in up against the clutch fork and see how far out the slaves bolt holes are out compared to the ones on the box, that'll give you a rough idea of how much shorter the rod needs to be.
this problem sounds all to familiar. i had this problem with my ts2cd. clutch would not engage properly. it ended up being the sleeve and bearing combo.
i finally got the right combo after pulling the box in and out 3 times. i wish i could tell you the part numbers but i forgot. however the clutch is no longer in
the car so if i find the sleeve and bearing floating around the garage ill get the part numbers.
After doing alittle research on part numbers.
Knowing that these numbers posted and recomended are old.
It seams that the sleeve 30501-U0200 has been superceded by part number 30501-A6801 AND that has been superceded by part number 30501-S0284.
I was sent 30501-S0284 and after research it is an 18mm sleeve.. ?!?!?!?!?
How and why would a 16mm sleeve be replace by an 18mm sleeve.
Well I ordered a 14mm sleeve.
30501-N1604
will report back when i get it installed to see if it fixed me issue.
Haha this happened to me cos the silly mechanic put a washer under the clutch pivot ball, i diddnt want to drop the box again so i just shaved a bit off the slave cylender rod, worked fine, released the clutch.
  • 4 months later...
I'm having the exact same issue with a ts2b clutch. The carrier recommended was a 20mm. We didn't put the box back on cause it was starting to compress the diaphragm springs. Luckily I have 2 shorter carriers we're going to try out. A 15mm and the one I got with the clutch which was machined down to 8mm!
Hello,
I bought the STR2CD (used) and according to the (Japanese) manual the sleeve bearing is supposed to be
14mm and 30501-N1604.
There is an English translation of that manual but it is lacking this bit of information found in the Japanese manual.
http://www.osgiken.net/upload/d42.pdf
So did the 14mm bearing solve the issue or is there anything else I should be aware off?
Thanks
For the TS2CD the sleeve bearing is 12mm (as per Japanese manual)
Page 4 illustration 3 of the os giken link is a step that tends to get missed by those not in the know.
I had both the twin and triple plate os clutch kits in my 32 that needed the input shaft snout to be cut 4mm as well. Same with mate's os twin in a 300ZX box.
Not trimming the snout will cause the snout to contact the pressure plate fingers causing the clutch to half disengage, grind the snout to a pulp of aluminum shite, and make the throwout bearing and carrier unable to fully disengage clutch, as it will hit the damaged part of the snout that is now mushroomed....
I've been down this road....
Also another couple of things that may break are the pivot ball, and clutch fork from excessive force from trying to get the carrier past the mushroomed/ground up snout.
OMG!
This sounds bad .. but only seems to apply to the TS2?
Also I found this document:
http://www.osgiken.net/upload/d43.pdf
It says I should use the release bearing supplied.
So (hopefully) no sweat?
    • Hi guys my 94 r33 gtst fuel pump has gone out. I have a walbro 525 ready to go in but am unsure if I need to upgrade the fuel tank bulk heads? Ive heard that others have issues with the stock wiring melting... Ive seen alot of people recommend this: https://frenchysperformancegarage.com/products/fpg-nissan-skyline-r33-r34-silvia-s14-s15-billet-fuel-tank-bulkhead-hat-top-an6-with-high-current-connector-apex-2-8-delphi-fpg-100?variant=42873255198898 My current pump that stopped working is aftermarket but I had no relay mod or upgraded connectors. Need some advice please. TIA
    • It’s new. It’s the cd009. I did take the transmission apart to mill down the bellhousing and had both housings come off the gears so wondering is something isn’t in right. I am running redline. I can get it in gear running too but it’s just not easier and it’s almost like 2, 4, 6, and reverse all the back gears aren’t happy going in
    • I’ll remember that as a last choice. It’s brand new
    • Got keys and did a walk around the yard planning the landscaping works with the family that I will be doing Main effort: remove all the woodchip in the gardens that are around (attached) to the outside of the house and replace with 10mm blue metal, having woodchip close to the house is a recipe for inviting white ants, currently there are no white ants within the block and I would like to keep it that way I'll be buying some large raised garden beds to grow veggies and stuff, and the woodchip will be mulched with everything else that gets dug up, pulled out, or cut down during works Next will some minor drainage and landscaping maintenance up one side of the house, where the fuse box, AC, and solar stuff will go, about 12 mtrs long by 2 meters wide, I'll break up the soil, add gypsum and then I'll dig in a French drains about 300mm deep x 300mm wide and fill it with agg pipe and blue metal, then level out the whole area with a 50mm layer of blue metal, the soil, whilst currently pretty compacted, will break up well with the gypsum to aid in drainage, I'll then cover the area with a 50mm layer of more blue metal In saying this, the drainage issue is minor, but that little hidden away area down the side is untidy and weedy, and as all of the main elec stuff is there I want it neat and tidy to appease my OCD Again, the material excavated from the French drains with be added to the garden bed mulch, as will some rose bushes and some other crap looking garden plants, and a old apricot tree that is looking worse for wear The apricot tree is currently in a little roundish garden bed that is in the middle of the back yard with few other crappy looking plants around it, that will all be removed, levelled, re-turfed, and is a perfect spot for a hills hoist There is also a area about 3m x 2m between the rear fence and shed that will get some attention, it looks like some stuff was stored there and the grass is dead, that will also get broken up and mulched, and is a prime spot for a pumpkin patch I've guestimated that I'll need: 3 tonnes of blue metal, 12 meters of agg pipe, 5kg of Gypsum, and a hills hoist, so a few bags of concrete as well to set it in place (the house currently has one of those pull out 4 line jobs, whilst it works, I want a retro old school hills hoist), I am also going to run some chickens, there's a great spot for a coop, so a chicken coop to suit 4 of those lovely egg laying bitches will also be on the job card That should keep me busy for a while, and will finish off the back yard ready for a early spring planting of some veggies and berries  Once the main effort is done I'll start out the front, there's a large rock garden that could use some TLC, but that is only minor works Should be fully moved in within 2 weeks, the landscaping works will start then Fun times, retirement is good
    • It happens, that's what your single stage filler is used for.  If it is still visible after the 3 coats of 2k primer, it will be visible after the paint is laid down.  Its hard to give 100% perfect advice without being there in person, I'm very tempted to say stop where you are, fill your pin holes with a single stage putty first then keep going.
