The owner is called KURT and his contact number is 0414 906 949.
He has done all the work to his 33 and is starting work on a white 33 which blew a piston at the powercruz.
he imports parts and are really cheap so give him a buzz if your after anything.
ps - i made all the stickers for there cars :D
https://www.sau.com.au/forums/topic/40076-secret-garage/#findComment-823875
