2 BRAND IN THE BOX GENUINE TURBOSMART 45MM HYPERGATES..........THEY CAME WITH MY HKS TWIN SET UP BUT I HAVE TIAL MVR 44MM GATES IM USING SO NO USE FOR THESE
$370 EA
BRAND NEW NEVER USED CUSTOM JNT CATCH CAN WITH AN FITTINGS AND A BRAND NEW K&N FILTER $160
20 STEAM PIPE BENDS 5MM WALL THICKNESS WITH 39MM ID $90
CUSTOM PWR INTERCOOLER 760X280X90 700
CUSTOM JZA80 TWIN TURBO EXHAUST MANIFOLD TO FIT TWIN T28 TURBO'S $350
BRAND NEW GODZILLA BOV WITH FULL FITTING KIT WITH EXTRA'S
$240
BRAND NEW 1 TIAL 38MM MVS WASTEGATE
$270
2JZGTE POLISHED LOWER INLET MANIFOLD RUNNERS AND FUEL RAIL$300
SHOW POLISHED 2JZGTE ARISTO STOCK TWIN TURBO PIPNG $280
BRAND NEW 2JZGTE BILLET COIL COVER FULL SHOW POLISHED $170
WILL UPDATE WITH MORE PARTS SOON
PICS HERE
Webshots Rides offers thousands of the best car wallpapers.
PM OR 0404832055
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
    • Make sure to have the block checked for cracking etc before doing anything.
    • Pull it out. Put a suction hose on it drawing from a bucket of petrol. Put a discharge hose on it pointing back into the bucket. Add 12V. That will tell you if it works at all. Then put it back in, turn the engine on, and see if there is 12V on the terminals. That would suggest that it runs when the car does and adds its "capacity" to the total pumping system.
    • So you're telling me this is an external fuel pump? I've had the car for at least 6 years now and it's been there the entire time. I had the car tuned a couple years ago and I had the shop do the fuel system, including a new in-tank Proflow 340 which shit itself about a year later and I replaced it with the same model. I find it odd that they didn't remove this or even make mention of it. I seriously had no idea what it was. How would I test if it's functioning?
    • Don't take it as a guarantee. It's all a game of statistics. And on top of that, smooth over a thick layer of "quality of spanner spinning" as a further Gaussian curve of probability of failure. You play games at anything above ~400 HP, and you're using up margins in terms of engineering and luck.
