I am hoping someone can confirm that the R34 4wd can be temporarily disconnected like the R32 with just the removal of a fuse. I heard this down the grape vine when the R34 was released...
The R33 is definitely different and needs a center diff controller.
  • 5 weeks later...
As you can uderstand, I dont want to Give it a shot on a 95,000
car.
This is needed for SEV's testing and they only have a 2wd dyno to do
rolling road emissions. For those of you that dont know, SEV's testing is required
for import compliance plates.
This is why I need to know if it can be temp disconnected. To a more details extent
what happens with the factory computer and what happens on a 2wd dyno.
Another thing I am concerned about is the computer going into limp
mode because the front wheels are not moving but the rears are.
I can put a PFC in it but dam, tunning it for emissions is not like tunning it for power, I can hire I dyno for good rates but if I hire one with all teh emmsions gear (full gas) its nearly $300 per hour! I need to know what I am shooting for.
FYI emissions tuning is a lot more time consuming then power/economy.
If this is for SEVs and your doing emission's testing wouldn't it need to be done on a 4wd dyno, in case there is any extra pressure on the engine and it outputs more to get around that pressure placed on the engine?
Maybe you should check to see if you can use a 2wd dyno for a 4wd car to pass SEVs.
i have popped a 4WD fuse in my car and i had only 2WD at the time.....after i replaced thye fuse the car seemed ok....however i dont know if there is any adverse effect from extensive use of the vehicle with this fuse removed or blown...i have also done the same with a 33 GTR that i had quite some time ago
Benjiman74 have you run a R34 in 2wd mode?
Zagan No one has a 4wd dyno with the correct emmsions gear. Hence 2wd mode. It can not go into limp mode as it will change maps altering emmisions. I have checked and it can be run in 2wd mode for emissions purposes.
yldgtr2 that would be in a R32, R33 and R34 are differnt and you cant pop a fues as far as I knwo.
Minimum the ABS light will come on, whether this will cause a limp mode activation is another story.
Hmm, might have to go to the R34 forum
No i haven't removed the shaft on an r34 as I don't own one. I sugggest you refer to Snowman's post #11 (he owns an r34 gtr) and vspecv's post #16 (he's had several gtr's including r34's). Both have advised you to remove the front shaft.
My personal experience with the r33 is that the ecu will did not go into limp mode, simply adjust your driving style and enjoy. :wassup:
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
