as title states
im looking at getting 18x10 +24offset. with R disk and O disk for rear (more dish) but heard i must get r disk for both? frown.png anyone know about this?
want it to sit flush and agressive but with no rubbing. (dnt want stupid camber spec either) Just inside the guard would be ideal for lowering purposes.
what are others running? pictures? did you need to do any modifications to fit?
thanks.
Edited by JesseJ
https://www.sau.com.au/forums/topic/400841-best-widthoffset-combo-for-32-gtr/
i think a R32 GTR could take a bit more offset then +24 i run +20 on my GTST and its flush and my mate also runs +18 on a 18x10 all round on a GTST, so i think you could sink in some +20 to +15's in there nicley and depending on how aggressive the look your going for is +12 i have seen looks mint ;)
dude use the search function there is sooooooooooooooooooooooooo many threads. like the R32 pics thread half have rims pics and rim sizes and offsets.
32 Gtr - 18x10+12 is do-able.
look at my content, posted a few of my car with rota grid R with the above offset. looks wickid tough agressive and then some.
only issue is my car was lowered a bit, had front rubbing on passenger guard. annoyed the crap out of me.
personally for sake of $$$ in wheels and tyres im looking at 17x9.5 +15,20 wheels next time. and spaced accordingly maybe 10/15mm bolt ons.
end of the day its your car.
Hope this helps!
Yeah with appropriate height on car i.e. not dumped on its ass.
You can do 18x10 +12 no dramas without rolling lips.
If you want a dropped car with camber etc you can do bolt on spacers, and then lip guards etc to suit.
thats running 265/35/18s btw with a tiny bit of stretch, could run 275's i think then on a stock gtr you start running in to problems.
for a road going car i wouldnt go any bigger personally. looks tuff, rides well enough not absolutely rough as guts and will def fill those pumpd guards!!
get em.
running 18x10+18 with 275 tires all round
issues = tires rubbing on rear gaurd so we rolled it problem gone,
also passenger side inner plastic gaurds rubs a bit on full lock.....doesnt really bother me though
Thats the thing, i want it faily low :)
18x10 + 18 seems to be a good combo (going from another forum) or maybe play it safe and go slighter higher so i can lower it how i want..hmmm
good to know rolling the guards = no rubbing issues (Was it rubbing on inner or outer or both?) - could you tyre tuck if you wanted to?? any piccies?
Edited by JesseJ
front wheel just rubbed on inner gaurd only, rear rubbed on outter. To tuck the tires in on a 18x10 i see guys running 265 tires which tend to just fit under gaurds without needing to roll them
hers some pics of how it sits
  • 2 months later...
Old post but saves me starting a new one....when people say "roll the guards" does that mean the front aswell?
I got work xd9 in 18x10 + 18 with 265 KU36 rubber all around, scrubs a tiny bit at the height I've got it at (pretty low) so will prob get my rears rolled, what can be done for the fronts??
Remove upper guard liner and give them a roll too?
Set of Work VS-XX I've been working on. 18x10.5 et 23ish. Filled, drilled, and shaved mounting pads 8mm. R-disk front, O-disk rear. Natural weight camber curve will pull the wheel inside the wheel well as it is unloaded in the photo. Front looks the same. 4.5 inch lip on the rear, 3.5 on the front.
Car sitting on a set of Enkei RP01's. 17x9 et20 on Hancook Rs-3's. My gymkana set up.
Edited by warp speed
When u say shaving the mounting pads, do you mean the mounting surface on the back of the wheel?
I raised my car about 8mm all around today all seems fine now, not too keen on rolling my rear guards
Correct.
I've been told ideal/largest size for 32 GTR is 18x10' +20ish offset
Depends how low your car is as well :D
i just got work xd9's in 18x10 +18 with 265 KU36 tyres (which have no stretch on the rim)
definetly no way of tucking them in the guard, but if you roll the guards you can wind the coilovers down another 10-15mm and it wouldnt scrub
mine have about a 2 finger gap between wheels and guards....
Ah ok, well I have 18x 10.0 at around 15-20ish off set ( can't remember) though I do have my guards rolled..That's with 265/35 federals
If I wasn't interstate I'd walk outside and see if the fronts were rolled for you :)
Edited by GTR_JOEY
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
