A Day In Court
If it doesn't have a bunch of funky bends, then yes, you can just use straight hose.
I saw on Amayama most of the rubber hoses are actually available and mostly very inexpensive, but I don't think I can get every single one. Is it possible to make these hoses myself?
Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid) and made an oil port on the cam cap to lower pressure in the journal. Difference is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm. Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
