If you're on a budget just go a Kando T67 or TD06, Yellow Jackets will be fine, run series 2 yellowjackets because they have built in ignitor's. Injectors 1000cc Injector Dynamics, cheapest ive found so far are from Lewis Engines. Plenums...depending on budget, ebay FFP, greddy FFP, plazmaman plenum to keep you're long runners. Throttle body 80mm is MAX you'll need. Exhaust manifold, porting will cost almost as much as a 6boost.
EDIT:
injectors flowing more than 500cc/min are usally low impedance injectors because of the faster response times of the peak and hold pattern
and it depends what fuel rail you run, most common is 11mm and you cant beat ID injectors.
Edited by 51NNA
  • Replies 43
Depends how set you are on 300+kw at the wheels.
You can get near enough with stock manifolds (inlet and exhaust). A GT3076 will bolt to the stock manifold with a spacer.If you do want a front facing intake your stock throttle body will be fine for 300kw++
What kind of Stagea ecu do you have? If it has two rows of pins it can't be Nistuned. If it has three rows (like an R34) it can. But I would save the money not spent on manifiolds (at this stage anyway) and buy a Link/Vipec - then you won't need any kind of afm and will not need to update your ecu again.
I have a mines chipped stagea ecu & a r33 s2 ecu that can be nistuned. So you reckon link/vipec are better than the haltec sprint 500?
I'm not really keen on buying another ecu seeing as I have the r32 one, a mines stagea one, an r33 one & the haltec haha.
As for manifolds I'm going eBay forward facing ($200) with billet fuel rail & getting my stock exhaust manifold ported for free off a mate.
Will one 040 do my fuel needs of 300awkw on e85? I'm keen on an intank pump, any reccomendations? 2 040's?
Cheers
"NIStune Type 2 Board
M30 Infiniti (VG30E)
ECR32 Skyline (RB25DE)
ECR33 Skyline (RB25DET)*1
HCR32 Skyline (RB20DET)
BNR32 Skyline (RB26DETT)*2*3
Q45 Infiniti (VH45DE)*4
U12 Bluebird (KA24E)
Y60 Patrol (TB42E)
Z32 Fairlady 300ZX (VG30DETT)"
The asterix next to r33 means that there are conditions... On the nistune website scroll down and read the asterix and you'll find you need to use a z32 ecu or rb20 ecu.
Z32 will keep Vct and rb20 ecu will need an rpm window switch to keep Vct.
As for fuel pumps, have you considered an 044 Bosch pump mounted intank?
Edited by Mitcho_7
I've seen plenty of r33 ecus nistuned??
he is on drugs :) no r33 nistune. Guilt toy is a big fan of the sprint 500's, he uses quite a few nowadays he may be worth a PM.
Im still a LINK fan ($1550 - 1650)
You will need more than 15psi to get 300 .... and as far as reliablity goes it will be fine as long as your tuner knows what thry are doing best ecu and setup is useless if your tuner has half a brain .... Pick a shop and see what ecu thry prefer is a good idea .... honestly the better ecu with maffless tune will save u cash on the z32 so will be around the same money if u work it out..... my mate runs rb25 stock bottom end with cams 256 cam gear gt35r turbo haltech pro pluin reloacated stock tb on factory mani for forward facing and yellow jacket coils for 344rwkw on 22psi safe tune for drifting wheel spining on the dyno in top rpm tuned by JEM on E85 hope that helps :)
I stand corrected! Wondered what was the go with the *1..,
Blitz so what injectors + fuel pump is your mate running??
Im after the walbro intank 400lph (walbros biggest) and 1000cc injectors.... Overkill for my setup?
That's going to be pretty much my exact setup. 344 @ 22 surely I'd be atleast near 300 on 15/16 with a fresh buit motor + port clean up etc?
so 3076 seems the turbo of choice? and 300awkw hard to reach on 15psi even with fresh motor, + haltec + cams + e85?
if your wondering why 300, because thats about the limit of my budget + pretty much the limit of reliable streetable driving IMO / unforged rb25 limit (yes?)
decided on 15psi (/1bar) because thats all i want to run, not really keen on 20psi and getting mad numbers, and another motor in 6 months time.
topic probs should have read "after the most power i can get reliably on 15psi
Whether you run 15psi or 25 psi makes no difference to the reliabilty or longevity of your engine (supposing that you are running a turbo within its design limits) - that's down to the maximum power, and as you say 300kw is often quoted as a sensible limit for a stock block motor, the way its driven and maintained and most importantly the tune.
Plus boost control kit, iat sensor xs harness :) wicked bits of gear
i dont use the boost kits in 99% of cases tbh. i include the IAT for that price. Generally most guys wont need the xs harness either.
True about the xs harness. Do u not Like the boos control kits?
They are fine, i just prefer a simple wet and dry boost setting via EBC with peak recall and warnings etc. If the car has a digi dash etc then internal boost control is best.
These are my preferences everyone is different.
WTF is with all this talk of MAF-less tunes? Thought I was on a Holden or Ford foum for a sec.
As stated a few times now, youre still not understanding that no turbo is going to do 300 on 14psi. Whether you have 10psi or 30psi wound in, 300kw still has the same amount of stress on the engine. The only difference is the setups tendency to become dangerous or damage the engine. No a 3540 wont do 300 on 14psi and it would be a laggy sack of shit if it did.
Also if youve checked the RB25 Upgrade thread you would see that stock 25s can easily run 300-350 all day every day. Shit, theres a thread dedicated to it. So with your built one, im sure itll be fine at 300 if the tune is good, and youve got the added security and ease of making power with E85.
Go the 3076 and wind 20psi in. Itll be everything youre after.
He has a port clean up done rebuilt motor wont add power u still need to run 20psi ish depending as its in thr turbos efficency range dont be afraid it wont hurt it its the tune that will good tune will be fine with that power level .... he has twin intank walbro 255 pumps and 750cc high flow injectors from pj no 1000s will be fine
Never said14psi. If im struggeling for the numbers im after ill go higher but not going to 20psi. But for the sake of it, take boost out of the equation. It's irrelevant I guess anyway.
Yes I have checked the rb25 upgrade thread, but I'm after info more specific. My iphone won't show the dyno sheets + saw pages & pages of stock turbo, stock ecu, stock inj etc which I'm not interested in.
- is the tomei poncam 256 with 8.5mm lift a good choice for easy drop in mid range power? Or should I go more aggressive?
Thanks all
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
