Gday Guys,
Started off with the intention of buying a GT-R Hence the username, after months of searching with just not finding what i wanted came across a Bright orange r32 GTS-t for $7k.
Exactly what i wanted at the time so pretty much bought it on the spot, had some issues to begin with, advised the timing was retarded causing lacking performance from the dealership i bought it from, Me not knowing to much about mechanics of cars was like oh yeah, sweet as, easy fix. Turns out car was actually running on low compression lowest being 20 highest being 90. So she was f**ked.
Anywho, car also was sold with wrong gearbox and dodgey suspension, so it was pretty much rip it out and start again. Got the guys at CMR Motorsport to hook me up with a rb25 half cut and put that in for me.
This is where i am now!, july rolling round and the intention is to do fmic, gt3582r, 750cc injectors, bov, and tune all at once.
Current figure on 165kw at the wheels, hoping for around the 320 - 350kw atw. will post up some photos when i get a chance!
https://www.sau.com.au/forums/topic/400871-r32-gts-t-build/
    • Maybe I also should have wrote that a bit better lol. I did come 8th last in English at school during the HSC, ironically spent 2 decades reading/writing specifications and contracts in IT 😂
    • Right, but that's in-cylinder, there's the interaction between that and the TWC which complicates things. Pulling out timing to reduce NOx is a strategy I saw in transitional emissions vehicles like stuff from 1974 or so. The two inlet runner system is interesting but I'm not sure it makes a huge difference as far as emissions goes, is it a tumble valve? I've seen stuff like that even in cars from the late 80s.
    • Hello all,   so i recently swapped out my rb20de neo with an rb25de neo( engine,transmission, wiring and the diff everything) but i just cant get the gear indication light on the dash to work when i switch to tiptronic mode. Note there is a steering wheel switch beside the shifter and i dont have that. I did notice yesterday while switching to tiptronic that the indicator on the dash started to work but it didn't afterwards. Does anyone know how this actually works? Or do i still need that steering wheel switch to be connected and on for that gear indicator to work?
    • Hence why I said earlier that I don't think the turbo Neos ever would have actually qualified as an LEV. I suspect the only actual LEVs that came out of Nissan were the NA Neos. Still call them all Neos. They all stil have the Neo-ness. Just that they don't all qualify as as LEVs.
    • It will give gains, but you wont hit 600 It will give gains but it wont get you to 600 imo. You will also sacrifice low down and you will be adding extra volume if you port match it, more so if you port the plenum runners depending and how its done I think the only time youre going to see about 100hp gains is if the car is making well over 1k kw I do have a spare set that I was going to test with, but i dont actually think there is anything worth getting going larger. I did a fair few S14/S15 and the standard TB is fairly small, I went to 60 and in some cases 64mm which is significant over the stock unit. You can also get some weird ratio changes. I think 20kw will be a stretch on a roller dyno. If I had it apart I might mill the shafts a little and not expect much, I think the stock size is still pretty good for a street/track car even with larger capacity. I might change diameter it if its a drag only car
