Why the non-desire to run 25 psi? You're only going to be doing it to compensate for lack of mechanically obtained cylinder pressure, aiming to get to the same cylinder pressures that you wanted originally.
Just do it.
And contemplate ensmallening the cams. Doing so would be perfectly cromulent.
  • Replies 53
Posted 24 May 2012 - 11:05 PM "thanks bud ill have to book it in for another tune but i really dont feel like runing more than 25psi of boost i know the engine is built and all but i do want to keep the car for a bit longer and reliability is my no1"
Boost level is not a factor in engine life. Fear of high boost probably derives from the inability of the stock RB25DET turbo to run safely at much more than 11 - 12 psi and then it was the disintegration of the turbo ( and subsequent risk to the engine) that was the danger not the amount of boost per se. Max power is a factor in engine life and a bigger factor is a good tune.
ill speak to my tuner and see to bump up to 25 psi, other thing i am considering is running E85 like BMYHOE
but will my fuel set up be enough for the E85?????
the only think that sort of draws me back from e85 is the octane level does change from season to season, the blend falls down to about 70% -30% in colder seasons
thoughts????
thoughts????
Caltex hasn't changed much from 70% since it was introduced. I would run Caltex in winter for the easy cold starts and swap maps to United in summer if you want the e85.
I saw this today and couldn't believe the power the SR was putting out with a GT35...
http://www.nissansil...howtopic=519247
i find that power figure out of a standard GT35 hard to believe. i have only ever seen a couple make more than 420-430.
thoughts????
Tune in winter when the pulp content is higher, Not that it makes any differece unless your tuner is taking your setup to the ragged edge,
My setup was done in winter then rechecked a couple of times in summer , no issues what soever.
Once you have used e85 you will never go back. The car runs so much better and engine temps are noticeably cooler. Good stuff!
im running 24psi but spike back to 19 by redline..
im using clatex e flex fuel as above it hasnt changed its ethonal rating since i started using it - NOV2011
you may need to add anther 044 fuel pump possible dash 8 fuel supply line..
not sure on the 850cc injectors in using 1000cc's
yeah i spoke to my tuner today he said at the same boost level (19psi) using e85 we should see somewhere within 350-360rwkw mark using the same fuel set up that i have now but bumping up the fuel pressure a bit. He highly recommended it.
if i do decide e85 and 25psi boost then my future intensions are
1000cc injectors like you said
earl braided fuel line
and another 044
thanks all on your inputs
well guys today was the sad day for me i found out y i only ended up mking 320rwkw,
ill start at the beginning
My friend had the car i have now, he has had the engine built by SMD workshops in sydney and had it tuned there too only a run in tune though.
i decided to buy the car of him and get it tuned there too, by the same guy using ems stinger ecu.
becuase i was buying the car i had to ask him what was done to the engine what pistons rods other things he used. fuel system etc
he said he had a 50mm greddy , external gate, greddy 850cc injectors, the whole ignition loom was changed blah blah blah, but little did he know that i have a bit of knowledge about cars unlike my unfortunate friend.
when i went through the whole car i figured it was starting funny, noise was a bit different which put a question mark in my head, i realised its got nismo 555cc injectors, cheap $110 ebay external gate, ignition loom is original as its a ser 2 loom. and all the other bulshit he said was not right,
i then ended up putting an external fuel set up surge tank 044 etc. nismo reg, with a real 850cc injectors, turbosmart 45mm pro gate etc etc
he couldnt get it tuned it was overboosting then it was just runing gate spring pressure boost and all other dramas including timing which he said it was ok but when i checked it the base timing it was 30 degrees in advance, and i said just leave it cos the car was going on a truck to adelaide the next day.
i ended up putting haltech plug in platinum series ecus and had it tuned everything finally fixed, new plugs etc etc everything done properly and ended up making only what i made.
now to cut the story short i realised my oil catch can was filling up with oil it overfilled and spilled everywhere on my driveway and along the LH headlight
i knew something was wrong so i did a compression test 1 cylinder was good 2nd, 3rd, 4th,it all went fine until i checked the cylinder pressure on 5th cylinder where i found only 60psi of cylinder pressure :( hmmm
an engine that has done less then 5000km has gone ka boom
suprisingly the car doesnt blow white smoke at all
well who is to blame tuner, builder, myself???? but ill not point a finger at anyone cos shit does happen :( although i wouldnt trust the guy from SMD workshop in sydney thats all he made me realise that he talks a lot of bull crap, anyway
the car still drives awesome with pleanty of power lol :) but i just know what i have to do,
head off to figure out what went wrong :(
other thing i found rear exhaust muffler the inside diameter is only 2.5inch :(
yeah well they are supoused to be Je pistons, have shotpeened rods, all acl bearings, cometic multilayer head gasket, arp bolts, etc etc but honesly i dont believe a thing he said, my friend did inspect the engine before he put it in and it all looked that its been properly built, but d question is, did he put that engine in it or a standard rb30 cos he did have few rb30 blocks there :/ will find out the hard when i pull engine apart
If its stock and he gave u reciepts its fraud
yeah it was preety much like that lol am not really pissed off its just it came at the wrong time i was always wanting to build an rb30 that can withstand a real punishment. maybe this is my time, SPOOL has got a preety good stuff that he sells. but finding a trusted builder in adel is a bit hard u hear stories of other people and it just makes u wonder :(
thats y i do as much as i can, i am a car sparky but have a broad mechanical knowledge
Don't roll over that easy, it's the principle of the matter. If it's been done to you and the guy gets away with it, what's to say he won't do the same thing to someone else again later?
I say confront the bloke about it, but don't start accusing him straight up. See what he says when you question him about what you have found.
Edited by Mitcho_7
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
