Hi,
I have up For Sale two excellent condition R33 RB25 Manual Gearboxes. I was planning on using 1 myself behind a 400+ kw RB27 and keeping the other as a spare but times and plans have now changed.
One is for sale as the ultimate R32 auto to manual conversion comprising of
- Complete RB25 Manual Gearbox with shifter, including custom made gearbox cross member with a Urathane gearbox mount to suit R32
- Modified Navara speedo drive/ sender so your R32 speedo still works
- YOUR choice of either a 1 piece Hardy Spicer custom made tailshaft or a custom made Hardy Spicer 2 piece. Both in excellent condition to suit R32 with the yoke to suit a RB25 gearbox
- Near new RB Xtreme 6 puk drift clutch, push type. This thing got used for probably less then 1 month Until I smashed the rear of the car. Has slight surface rust due to sitting in storage but you can still see the machining marks on both the flywheel and pressure plate surfaces and the friction plate shows no signs of wear. Excellent condition
- Clutch pedal and Manual brake pedal
- Clutch Master cylinder, factory fluid lines, and rb25 Slave cylinder.
The Ultimate hassle free R32 Auto to Manual Conversion!!!!! $ 1900ONO
Second Complete R33 RB25 Manual gearbox is also in great condition including a crossmember fitted with a New Nismo Gearbox Mount that suited a R32 perfect. Shifter included. $1400 ONO
I'm located in Morphett Vale, South Australia but willing to meet closer to the city if required. Would prefer not to post but can if required at purchasers expense.
Please PM me if your interested OR either or Call/ SMS me on 0438860807
Photos on request but they look exactly as you would expect.
Thanks For Looking
Interested in the 33 manual box only, drift clutch not required. I'm located in brisbane and happy to organise courier. Please give me a call between 0630-1830 if you still have this box for sale, cheers :D 0438 073 151
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
