Hard To Handle Mr30?
Hi
I have a Mr30 with a Rb25det etc R200 diff with a detroit lokka in it and its the hardest car I have owned to keep under control in a slide.
Is it the diff or suspension or just thats what 30s do?
I have replaced all the rubbers in the rear Koni shocks in the rear set near hard. I have a S13 front end to install and coil overs all-round I hope this helps as it feels like the car is out to get me every time I put it in a slide.
Its possible I have just lost my talent but I'm hoping not.
Any advice etc would be appreciated
Steve
Double check your alignment, front and rear.
Detroits have particular drive characteristics. That would be a factor - do you know how they actually work, and what to expect from one as you power on and then modulate the power?
Also how much steering angle is available in a MR30 front end?
If u been driving silvias all ur life then yea bit different. Lol i found mine when i had the 25 in it waz awsome.it loved it. Diff plays a major part so may take a bit of getting used to. Get i low some sway bar upgrades and good w/ a and itl be alot better. They love to skid just need to change how u drive them. Btw with s13 upgrade u will get more lock
I found when i had mine with the rb20 it was like a lead tipped arrow. very hard to keep balanced and most of the time its ass would swing out way too far.
problem is that the rb is very heavy on the front so you need a good suspension set up to make it handle best.
I had stiff konis and kings in the rear but 90/10's on the front wich was half my problem. perfect for drags and high speed freeway but try and drift it and was
usually 90 degrees+ to the footpath followed by slamming on the brakes.
so the s13 coilover option with a proper spring rate will help you out.
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
