Guys, I just registered as Stagea info is few and far between on the net compared to Skyline. Forgive me if this issue has been raised in another thread, but I got to like page9 and thought blahblah.gif
Here is my issue and it is a technical/mechanical one. Purchased my first Stagea, 4wd light was on solid. Began maintenance by topping up Attessa reservoir(righthand side of the boot). 4WD light went off. Driving specifically between 85-115kph, I would estimate, I have a shuddering or 'pulsing' sensation coming from what I believe to be the rear axle of the car. Like additional torque is being applied to the rear driveshafts momentarily in an on/off fashion. I would say that it is not a reducing speed sensation, as in abs acting on the rear wheels for some even more bizarre reason, especially as it only happens at a neutral or light load throttle position and the sensation is destinctly coming from the rear end. I have bled the attessa pump as per the instructions for a skyline except I couldnt find the plug to disconnect in teh drivers foot well like skylines are supposed to have. So we used a vacuum bleeder and me inside the car turning the ignition on and off to get pressure from the pump. Im will attempt to re-bleed tomorrow. We did loosen the nipple on the pump itself and had some drips to indicate no air but not entirely sure as it was the first time attempting to bleed an attessa system. Really hope someone can help. Any and all advice welcome smokin.gif
+1 for mismatched tyres, mine did that when I had two tyres the same size but different brands on the back so it is extremely sensitive, the pulsing is the attessa trying to correct for the wheels spinning at different speeds
Edited by Chris_Beli
The pump can be switched by undoing the plug which is to be found behind the drivers kick panel. It is a small plug in my case taped to another loom. However turning the engine on and off probably works just as well for your puposes. Tyre sizes are critical. In NZ it is anyway illegal to have different tyres on the same axle.
Hey, no tires are all the same all round. Nissans usually use an equal width tire allround by design. Im going to try the on-off ignition method again tomorrow for longer. Going to look for a drivetrain expert in my area who may have a gem of wisdom about this.
I have recently had a similar issue after putting a new wheel and tyre package on 19"s all round turns out the front tyres are the issue. My problem was mostly vibration in the steering wheel at around 90 - 120km. Cheap ass china tyres... Will be getting some Federal tyres on Monday.
Are all tire pressures equal ? All worn the same depth ?
Did any wheels lose any weights ?
Do you have a torque split gauge ? What does it do during 85-115km/h ?
Any crap on the wheel speed sensors ?
How low was the fluid before topping up ?
I have this same problem. Im pretty sure its the tyres too. I just put newies on the front and kept old no name shit on the rear to wear out. My left is more worn (i like to stick the ass out on the left :)) and yer the shuddering is really starting to piss me off. I will get new tyres and see if it fixes it and let you know?
  • 5 weeks later...
Can anyone confirm that it's the tyres?
Cause i just started having this problem since Sunday and it's driving me nuts!
Attessa reserivoir is full, got all exactly same tyres. I've changed nothing to the car and it suddenly started doing it....
I noticed that my speed seem to drop a bit faster than usual when I'm just coasting in gear at higher speeds, and recently sometimes i can smell something burning after turning off the car...
If you have a spare set of wheels for me to try it out that would be great!
Won't have time until early next week though. :-/
But it doesn't make sense if it's the tyres, since they were perfectly fine...
All good, I rushed to the mechanic the next morning.
While on the hoist, the wheel couldn't barely be moved only just wiggle a bit.
Disassembled the brakes and it decided to work fine again.... but there's still a very slight hesitation on the wheels.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
