hi guys thanks for the help
ive got an r33 and i want to make 300+rwkw, what can you suggest for me to do that i havnt done..
ive got...
dual roler baring high flow turbo (run 18psi)
nismo fuel pump
550cc injectors
microtech ltx12
blitz return flow FMIC
full 3 inch stainless steel exhaust
tomie cams + cam gears
will spiltfire coils do anything?
i havnt got it tuned yet but its booked in start of june..
thanks for the help
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/
coils won't get you any more power mate. only if your old ones are breaking down.
you'll struggle to make anymore than 350hp on a highflow turbo. you'd need something like a gt3071r or a hypergear atr43tggathkj. thingy. if you run any more boost than 18 you'll be out of the efficiency range of the turbs.
but looks like youve got most of the basic supporting mod!
+1 for big clutch.
ps keep in mind 400hp is getting close to the limit of the stock engine!
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/#findComment-6368849
thanks people and i forgot i have a exedy heavy duty cushion button..any other mods i havnt done?
well you've only just scratched the surface and the mods you've listed are practically bare minimal requirements...
and as others have said you wont make your goal power figure with your list of parts...
I guess we could start listing suspension, brakes and cooling mods to make it so the power can be used and controlled, but Im sure youve already done that yeah, right, yep done that uhuh...
whats with this magical 300 number anways...?
why do you want 300?
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/#findComment-6369160
Check out the hypergear thread if you want to keep the stock manifold and dump. Check out the kando thread if you dont. I vouch for the hypergear atr43g3, with those cams, you should see 300rwkw. You can install it yourself if you're confident enough and have some tools. I hear lots of stories about those return flow coolers overheating, not sure about the blitz ones.
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/#findComment-6369354
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
