hi guys thanks for the help
ive got an r33 and i want to make 300+rwkw, what can you suggest for me to do that i havnt done..
ive got...
dual roler baring high flow turbo (run 18psi)
nismo fuel pump
550cc injectors
microtech ltx12
blitz return flow FMIC
full 3 inch stainless steel exhaust
tomie cams + cam gears
will spiltfire coils do anything?
i havnt got it tuned yet but its booked in start of june..
thanks for the help
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/
coils won't get you any more power mate. only if your old ones are breaking down.
you'll struggle to make anymore than 350hp on a highflow turbo. you'd need something like a gt3071r or a hypergear atr43tggathkj. thingy. if you run any more boost than 18 you'll be out of the efficiency range of the turbs.
but looks like youve got most of the basic supporting mod!
+1 for big clutch.
ps keep in mind 400hp is getting close to the limit of the stock engine!
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/#findComment-6368849
thanks people and i forgot i have a exedy heavy duty cushion button..any other mods i havnt done?
well you've only just scratched the surface and the mods you've listed are practically bare minimal requirements...
and as others have said you wont make your goal power figure with your list of parts...
I guess we could start listing suspension, brakes and cooling mods to make it so the power can be used and controlled, but Im sure youve already done that yeah, right, yep done that uhuh...
whats with this magical 300 number anways...?
why do you want 300?
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/#findComment-6369160
Check out the hypergear thread if you want to keep the stock manifold and dump. Check out the kando thread if you dont. I vouch for the hypergear atr43g3, with those cams, you should see 300rwkw. You can install it yourself if you're confident enough and have some tools. I hear lots of stories about those return flow coolers overheating, not sure about the blitz ones.
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/#findComment-6369354
