Rekon something bigger will work well?
Ive done T28 (works good on 9.5:1), 28RS disco, TD05H 18G. The Disco was very fail, I suspect due to cams, the 18G has gone over 200kw but pings with any more than 15 pounds.
My 10:1 motor has been shit from word go, all other 9.5 motors Ive done have at least always been fast. Im currently rebuilding my old DET to make way for an FP30, unless you rekon the 10:1 motor will take to the FP30 as is ? lol, id try it if there was merit (want to stay 98 though).
10:1 would work well with 98 but only with upgraded cams, a bigger turbine housing and low-ish boot. No need to run big boost wen u have high comp, cams and very little backpressure in the exhaust manifold.
  • Replies 82
Someone sponsor me and Jez to put some ethanol in my SR.
My current SR is 10:1 and very det prone. I wouldnt mind letting jez see if the pineapple juice makes it a monster, would be good for everyone to see.
For science ;)
can't you just fit that water injection kit you have?
cheers
darren
I will pay for 40L of E85 if u wanna try the real mans fuel.
But i think the boys are right maybe weve been trying the wrong setup and we need a bigger turbo. Lets try that gr3040 highmount setup i have waiting for u. For the price its a bargain.
Exactly, that combo of GTScoT is a real mismatch way too much exhaust pressure... high comp small rear always ends in ping city. What are your exhaust temps?
Perfect E85 contender though for response / vs power..
Thanks for the pointers guys.
Weird thing is though, the first setup I went to tune with was a GT28RS with a .86 rear... Jez will confirm that after we swapped out the rear housing for a .64 it made an identical amount of power (tune needed to be backed off though).
You guys are tempting me to try harder with the DE+T but im realistically worried its just going to be another bout of CRAP. Am currently in the process of getting my old DET checked so i can buy some pistons for it :(
cheers
darren
I decided against it as my setup has proven too unreliable at the moment, i wouldnt want it to be useless without the WMI.
if i could get it to a point where WMI was an added bonus for big power but without was still awesome i definitely would.
on E85 it should be sweet, we did a high comp E85 S14 Sr20det with poncams and GT2871 and made 269rwkw on sensible boost... and stopped due to no injector left...
Problem is though he wont do E85 as its not available near him at this time. , trust me i have been trying since i first met him and his de+T setups
aah then WMI is the only option. Same result as E85 just requires a decent controller.
Also, what's the go with timing when tuning these things? Coz when we started at zero its knocking its guts out before you hit 3 degrees.
What's going to happen if you magically start at base timing (IE 15) and go from there? For science, obviously.
but what boost are you starting at?, 0-3 degrees is going to make the egts go waaay through the roof.... you need to start real low boost wise and watch your timing table as its is going to limit your boost dont let your boost determine your timing. Always aim to make as much power as safely possible on the lowest boost.
lesson learnt, we were starting at a bar.
so in theory if we started at 7psi and went for a mega aggressive tune, then fine tuned to compensate for boost as it increased.... we COULD have got there?
on the disco, it ended up with 210kw (regardless of .64 or .86) but extremely laggy. I had civics motoring away from me out of corners at wakefield.
yeah if it was a 16psi base actuator you were stuck, no good unfortunately. i reckon if you got a 6psi gate and started from there you would have been sweet.
Check it back on with WMI, did i read you had a kit? even at 16psi you should get about 8 degrees in it.
agreed yeah.
well give it another go with the 9.5:1 kando, but im gonna build the lower comp motor for my s14. I do have the WMI kit at home but im wanting to go an FP30. Already sold the disco so its just T28 powered for the minute. Might bring that for a retune if i get bored hehehe
  • 3 weeks later...
  • 2 months later...
dont want to be shaving the head that much to increase compression... you'll reduce the cumbustion chamber size.
need custom pistons with a higher crown height.
Would love to build a stroker RB28 with 10.5 - 11:1 CR balanced within a micron of its life to allow it to rev, Nitto spline drive pump to keep it lubricated. would be fairly nuts i would thing
cp can do custom pistons
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
