Thinking of putting a spec m front bar on my series 1, did a google search and both the series 1.5 and spec m front bumpers look the same? Are they the same thing or are people naming bumpers wrong? I mainly wanted to know if it is much lower to the ground then the series 1 bumper and if anyone knows what it looks like with standard series 1 side skirts?
https://www.sau.com.au/forums/topic/400933-r33-series-15-vs-spec-m-front-bar/
Is this what you are talking about? I had this on my S1 and as far as I can tell its no different to the S1.5 front bumper
89cal has standard side skirts, yours doesn't have any side skirts on it, that's just the body. His front bar is M spec/1.5 (same thing) and yours appears to be standard S1 base model.
haha...noobs..
actually I got a guy (wont say who but everybody who frequents FI section knows him) who always asks me where i got my special rare front bumper, cause hes never seen one like that..its stock S1...:laugh:
Ok thankyou for finally answering my question about whether M spec and S1.5 was the same bar! Initially I thought that mine just had small side skirts, I now realise it has none. Did side skirts come standard with S1.5?
haha...noobs..
actually I got a guy (wont say who but everybody who frequents FI section knows him) who always asks me where i got my special rare front bumper, cause hes never seen one like that..its stock S1... :laugh:
Yeah well i've been trying to source another series 1 bumper because I quite like them and mine is effed (dad crashed my car, believe it or not! ) but there are none around! all I can source is the series 1.5 bumper so I bought one the other day and will see how it looks without side skirts in a week once the rest of the car is fixed :(
  • 1 month later...
Hey mate where are you ? ill swap you my satndard series1 for your 1.5!!!
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
