Hi Guys
Have a white hr30 sitting in the garage i would like to get rid of. the car has been off the road for about 3 years now. would prefer to sell as whole car but if people want parts i could probs part it out.
Ironmask front end
s1 hotplates
rb20det conversion
highflow turbo
intercooler
link computer
alloys
lowered
exhaust 2.5 inch
r34 gtt seats
Have original seat still too
Have dr30rs factory 15x6 wheels
have spare s13 rear coilovers one is stuffed
have a spare r200 longnose diff also
has a little bit of rust and body damage
ignition module is gone as is alternator so doesnt start
engine has a bearing rattle
syncros are shot from 1st to second
give me a buzz if ya want a chat
0412 822 312
Brendan
car is located in victoria, watsonia 3087
https://www.sau.com.au/forums/topic/400940-hr30-for-sale-or-parts/
AHH I remember this one!
Probably 5 or 6 years ago, I think 'Rob' was the owner/builder. He had somethign to do with aircraft engineering at Morabbin Airport.
Was supposed to be mental quick, traction issues in 3rd gear in the dry even.
AN excellent base for a fast project car....
sigh......
  • 2 months later...
Bought this car off rob, pretty quick went even better after i hiflowed the turbo
blew away my mates ve clubsport no worries
still for sale
needing it GONE actually
someone come over check it out and make me a offer
in watsonia 3087
0412 822 312
Brendan
Edited by bc210
was this ever registered with the r20det and has it got an engineers mod plate or is it more a track worthy car now?
still keen on seeing the interior before i make the next move and drive out to see it
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
