  • Replies 99
the stock gauges are pretty shit, what air filter have you got on it?? defs recommend a high flow panel filter. same if not more power the a pod filter and its legal :)
other then a crap reading from the stock gauge, or the car not being able to breath or fart, i got nothing :P
do you know if its got the stock boost solenoid and all the standard tube setup?
Thinking of getting a water compressor or whatever they are called and a foamer... And give it a good claybar/polish/wax :D
My plans for the car is of course - zorst - FMIC - Boost controller - Tune . And hopefully be able to leave it at that :D
hopefully........ hahaha
Cheers
Colin
It wont....
I did similar thing
bought mine 100% stock
then pod, then cat back.
was happy for a month.
then turbo back exhaust + FMIC plus boost controller
went well until clutcfh died a week after
then had a fuel cut defender - SHIT.
ended up going to Unigroup where that was removed, other stuff fixed up
new ECU in,
car was great, 195rwkw on 10psi
not long after..
HKS GT-RS turbo, plus this and that (still standard motor) and made 255rwkw
and motorsport got the better of me.
keep it stock hahahahahahaha
no really, keep it stock and buy a second one already modded, it'll cost you the same in the loing run!!
In stock form boost stays at 5psi until 4500rpm then goes to 7psi, completely normal.
High boost solenoid mod is the first thing most people do. If you get a boost controller 10-11psi is as high as you can go before the ECU goes into rich and retard mode.
Word of advice, if you are on a budget just stick to the basic boltons. When you get to the point that you need to upgrade the ECU it starts to get costly.
Also have a clear idea what you want to do with the car BEFORE you start spending money, that way the path you take will become a little bit cheaper.
Hi guys, is it true that i can run approximately 10/11 psi on a 34 gtt intercooler if i swapped mine out?
Looking at maybe getting an exhaust with dual tips and a 34 intercooler so i don't have a huge slab of metal on the front keeping it looking stock =)
I can't afford to get a another one and want to slowly build this one up to a reliable ~ 200kw =D
hopefully 200kw = turbo back + 34gtt intercooler + boost controller and maybe a tune :D
Stock cooler is fine for 200rwkw, dont really want to get an ECU and tune for 200rwkw either.
Air filter
turbo back exhaust
11psi
You will have near enough 200rwkw.
Are you saying i can run my stock 33 cooler on 11psi with no issues? I always thought to run anything higher than 7psi i'd have to upgrade.
Would it be better to run a 33 or a 34 cooler?
Having a sidemount will be AWESOME to maintain awesome stock looks! and save some $$ =D
Thanks
Colin
Found out my issue about not running 7PSI. Was just my stupidity again. Read the dash properly and its in MMGH or something, and i googled it and got a converter which is saying its approximately 7PSI.
Will be installing a boost gauge asap to get a proper reading!
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
