Just to clarify things in my mind.... I stuck on the shim i bought to the back of the pad, then put the 2 metal backing plates ontop of them.
So i have pad - plastic stickon shim - full metal plate - half metal plate and the side clip that clips everything together :D
Sort of doubting if i need double metal plates.
I go pretty easy on my brakes no heavy braking or anything... Thinking of taking them out, giving them a good rub / sand... put them back in and give them a goooood bed in session, but its very hard to find anywhere to do it lol.
Ruxis - Won't be taking my stock skyline to the track ! hahaha
75coupe - Keep me posted how those shims work, i bought the HPX only because i heard they where quiet + no dust =(
Cheers
Colin
Edited by CLNSKY
  • Replies 99
Still getting used to the car, first manual car i've driven! Maybe in a years time when I know everything is running fine.
Back to the brakes.
Is it essential to have my adhesive shim + the 2 metal backing plates on?
Would removing the half backing plate (the one on the bottom right in the image) help with reducing noise, since its just plastic on one piece of metal?
Note: The image was taken just before i put the adhesive shim on.
Just rung GSLRallysports where I bought the pads / shims. He recommended I just stick the adhesive on the back of my brake pads and remove the 2 metal backing plates / shims (not sure what they are called but they are the OEM ones that are in the picture above).
Does this sound right? My pistons will be pressing directly onto the adhesive which is cardboard thin onto the pads.
I guess there's nothing to lose in trying? Should still be able to stop since the piston is pushing in :P
Would like to get some advice from you guys before i play with my brakes....
Cheers
Colin
Yep do it GSL know brakes, the replacement shkms are to replace the oem ones, the std shkms were originally covered in a thin rubber coating but after all these years its been heated and cracked off
Took apart everything, couldn't find any copper grease anyway and autobahn gave me some Bendix lubricant satchets and smashed it on and between the backing plates i have (still have the plastic adhesive on) BRAKES ARE QUIET!
I sanded down my brakes a bit, do i need to bed them in again?
Won't let me edit above post =(
Tried bedding in the brakes. First one or two stops where ok, but from there on the brakes where screaming when i did 80-10. Drove around for about 5 mins after i bedded them in to cool down. On the way home seemed pretty good with light braking.
Anyone know if they will stay quiet and only scream when they are very hot?
Cheers
Colin
Hey guys have a question for my exhaust i'm looking into.
Looking to get a catback system, cat, dump pipe (JJR stainless steel dump from Just jap) seperately.
Anyone heard of the brand VENOM before? My mate recommended the brand but he drives an XR5 lol.
http://www.ebay.com.au/itm/3-Nissan-VENOM-High-Flow-Cat-Skyline-R32-R33-R34-GTR-S13-Z32-300ZX-C33-A31-/260953990635?pt=AU_Car_Parts_Accessories&hash=item3cc211e5eb#ht_3586wt_940
Any recommendations for cats / dump pipes would be awesome guys!
Cheers
Colin
hmm, not sure. Depends where you get parts from - 2nd hand or new? new will cost a pretty penny, and 2nd hand, well, the panels and headlight can be gotten fairly cheaply, but it'd depend on if there's any reo bar damage. my massive accident was quoted up at just under 8k damage - won't post photos here, this was ~ 4.5 years ago. yours is considerably better than mine was!
if i had to guess on prices based on what i've seen:
bonnet 300
headlight 250ish
guard 200?
grille 50-100
not sure about painting it though!
I don't get to choose what parts i get through insurance do i?
Thought it was just replacing whatever i had before?
Or do i get to pick and choose :D
EDIT- Reo is fine, but they went into my radiator support rail... If thats what its called haha
Edited by CLNSKY
I ended up getting a different front bar - I paid for it, and it came off my premium, so essentially they paid for it (it was cheaper than a new front bar!). To be honest it's best to have a chat to your insurance company, see if they're ok with you sourcing parts, and go from there. If they are, then start digging through the FS section or something, but if they want to do it all themselves, well, good on them.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
