Where Are The R30 Injector Resistors/pack?
Am switching over the old leaking injectors in my 1982 HR30 with the L20 turbo motor but can't seem to find the resistor pack.
There must be one as it's running low impedance injectors(2.8 ohms).
Anyone know where to look please?
Edited by stewart1
Thanks!...I've read that Nissan used cheaper ECU's that needed resistor packs because they couldn't handle the low impedance injector amps.
My R30 definitely doesn't have a pack so if you are right they must have used an expensive ECU in only the R30 turbo model...interesting!
wow i haven't logged into SAU in A LONG TIME...
that pic is of your boost vac sensor (from memory)
I swapped my L20et injectors for RB20 ones ... pretty sure it was the na VL commonwhore ones @ about $80 each > maybe try searching for my old thread
good luck with those brittle old injector spacers and finding where you start sucking in air when you change them :)
- David
Yep it's a 1982 so 30 years old so needs some work,I notice the injector spacers are already broken (havn't touched them yet) and there's petrol bubbling around the seals.
I was going to but some RB20 injectors in which are 14.5 ohm(high impedance)and by-pass the resistor pack but seeing there isn't one I guess it's back to finding some low impedance ones.
Yes that's the boost sensor in pic,was showing wild fluctuating boost on the gauge so I broke it open and cleaned it,works fine now.
Just replaced the water pump recently as the shaft had wobbled out of it bush and the fan was hitting the cowl...it ontrack.jpgdeserves to be bought back to top condition after towing a horse jogging frame every day for the last 7 years.
Oh and it can still keep pace with my R33 RB25 turbo easy,don't know how but it does!
maybe it was the rb30 ones i put in then....... it was a straight swap
as for the injector seats, go to a wrecker and pull some off any L series they should fit
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
