soooooooooooooooo angry. lost the lock nut key to my rays wheel nuts........i was f**king using it earlier today. just spent 2.5k on new rims.....was about to put them on.
does anyone know where i can buy rays wheel nuts in adelaide?? or buy it off someone. soo tempted to drag out the grinder.
they look like the pic attached.
any help will be much appreciated.
thanks couchy
https://www.sau.com.au/forums/topic/400974-rays-wheel-nuts/
it's seven sided. a 25/32 socket will fit with a hammer =.=" but that's useless. i'll have another look when it's daylight and give wheelworx a crack
I have a rays lock nut you can borrow if you need bud. Just pm if you get stuck
Matty lives quite close to you Andrew - can quickly use his while you look for one to buy.
https://www.sau.com.au/forums/topic/400974-rays-wheel-nuts/#findComment-6370109
wheel worx are sourcing one for me. bloke said it'll either come from sydney or they'll have to order it from japan. f**king balls.
so just need to borrow a key so i can fit my te37sls on. lol i'm screwed if i get a flat tire.
https://www.sau.com.au/forums/topic/400974-rays-wheel-nuts/#findComment-6370564
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
