Hi from new member
Guest Reveddie
Hello
I'm new to this forum and would just like to say hi.
I own a silvia, but it does have a skyline engine in it, so I guess I can't be all that bad.
Any way I got to go
It was good meeting up with Urmine, ByBy and some of the other guys from down south who came up for drag combat.
cheers,
Reveddie
https://www.sau.com.au/forums/topic/401-hi-from-new-member/
Guest Reveddie
i have a Rb20det silver cover engine in my silvia,
Mods are as below:
T3/t4 hybid turbo
Microtech mt12
gtr injectors
600hp bosch intank pump
600x300 ARE intercoler
Oil cooler and remote mount oilfilter kit
hks pod induction system
big exhaust system, I think cam has already shown you the dump pipe,
Blitz bov
gab coilovers
cusco front and rear strut braces and brake mastercyld stopper
osgiken twin plate clutch which is being rebuilt atm
hks adj cam gears
c's quick shift kit which cam is always stealing
roll cage, race seats harnesses etc etc cusom this and that.
Yeah lots of crap, really...
Cheers reveddie,
https://www.sau.com.au/forums/topic/401-hi-from-new-member/#findComment-11497
Hi Reveddie
I was the chick that arrived sideways "drift style" in the R31 LOL!!!!
I actually own a wine red R33, but didn't bring it up for dragcombat :wink:
Was your s15 the pewter coloured one?? Welcome aboard the forums anyhooo!! :P
Shell :D
https://www.sau.com.au/forums/topic/401-hi-from-new-member/#findComment-11505
Guest Reveddie
Yeah i think i remember seeing you shell
You have shoulder length blonde hair and I think you had a pink top on that day. Was that slip's 31 that was sideways?
I was in the pewter s15, it was not mine though unfortunately.
Dom if you want to check the car out go to Boostmeiters site at
www.d-u-e-l.com and look for a s13 there's heaps of pics of what we've done to it, by the end of the week tunning should be finished andI will tell you what sort off power she's making.
We plan for somewhere around 230kw at the wheels at 1.2 bar
I like your 33 dom it looks pretty tuff.
Cheers eddie.
https://www.sau.com.au/forums/topic/401-hi-from-new-member/#findComment-11506
I was in the pewter s15, it was not mine though unfortunately.[/quote:812d5f59a0]
Yep that was me, and yes that was slip's R31, crazy lil dooooorifter he is (hehehe) :lol:
https://www.sau.com.au/forums/topic/401-hi-from-new-member/#findComment-11509
Hey
thought I'd introdue myself. I'm new to this forum so.....be nice!
I drive a HR31 GTS-r here in Adelaide. Done a few bits to it...
Peter Jackson Racing Blue 1989 R31 Nissan Skyline GTS-R Coupe
(manual)
Garrett GT25 turbo
Custom steampipe manifold
Big front mount intercooler (Japanese origin unknown)
K&N Pod filter
3"turbo back exhaust
Impul suspension
Nismo short shift kit
Nismo strut brace
HKS BOV
HKS turbo timer
HKS Boost controller
"A" Pillar boost gauge
190KW @16lbs
Planning on a new computer in the near future and a few more body mods....So thats about enough from me.
Ciao for now.
N :lol:
https://www.sau.com.au/forums/topic/401-hi-from-new-member/#findComment-11510
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
