Hey guys,
Ive just finished the painful process of extracting exhaust manifold studs, now apon inspection of my turbo (stock) I have noticed that the swing valve is loose?
Sorry Im not all that clued on with turbos but I am assuming that should be shut pretty tightly?
If it is supposed to be closed tight is there a way to adjust it? Not sure how it all works.
Btw the actuator rod is tight, just the circular swing valve is flappy :/
Cheers
Edit: a bit mor info, the reason for doing the studs was exhaust leak (duh) now, one of the symptoms I was experiencing was a flucuation in boost. Almost like a flicker as it was climing. Now I just assumed that was part of the leaking manifold but now... Could this be caused by this?
Edited by GoHard
https://www.sau.com.au/forums/topic/401007-swing-valve-resting-position/
A picture? I was trying to think how I could take a picture of movement...
I guess this might explain it? Should I be able to slide a piece of paper behind it when closed?
Its loose enough to spin freely with my finger. I hope this helps?
there should be some adjustment on the actuation rod that it's connected to it. adjust the rod so that flap is hard up against the seat. it'd be worth cleaning all the carbon off around the seat before adjustment.
cheers
justin
to me it sounds like there is more wrong with it than just the need for adjustment.
I dont think he should be able to freely move the wastegate with his fingers... or is it just the valve/disc that covers the hole that has some freeplay but the overall mechanism is still stiff and cannot be moved by hand?
Yeah mate the whole assembly is stiff as. Its just that circular disk that sits a bit loose.
See in the pic, i can grab onto the shaft (dead centre of disc) and it feels like very minute shaft play. I can spin it from there.
put some washers between the turbo and the bracket the actuator is on... :whistling:
What I really need is a washer on the swing valve to shim it, but there is no way of taking it apart to get a washer in there. Circlip maybe but thats worth even more :whistling:'s
This, should solve your problem nicely. Put enough washers on there to hold it shut and then an extra 2-3mm, should raise your boost a touch.
Justin, johnathon... Thank you. Thank you so much. A washer under the bracket of both bolts brings it closed perfectly!
Is this safe? There isn't much surface area for the bracket to sit on in the first place so I dont see why not. This has been done before?
Edited by GoHard
    • GTR front looks good. If you don't like it, I'll swap you a rolling shell R33 for it. Give you a fresh base to start with.
    • soon I also prefer the old look. At least I have more clearance for wheels up front now.
    • @PranK I think a few links in the original post need fixing...
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
