Thanks for all the replys, well in my situation i think it will cost me more to buy a standard box and a high flow filter for it then to fix up my pod.
I love that intake piping dan!
95GTST theres another member selling them for about 190 i think? and the uas ones are 195, thats where i was getting that figure :)
I might be interested in the one you organised, do u have any left?
http://members.optushome.com.au/jay51/Fron...hrottlebody.jpg
The foil backed foam is fine and doesn't transfer as much engin bay heat as a hard box. Best to use a double layer of foam though. I use stuff with foil one side self adhesive the other. Makes a box 20mm thick foam with foil inside and out
I done my CAI myself, just cut some of that heat sheild foam to shape, Then enlarged the spare cooler piping hole out to 4inches, made a mould out of chicken wire and masking tape to go from the 4inch hole to that hole in the front bar (400r, next to the blinker) and mould around it then just covered the mould in fibre glass and when it set ripped the mould out (sorta like paper mashey). It works really well, i have a rush pod and before i done the cai the metal bell bit was always too hot to touch but now its always cold like not even a bit warm.
