Wiring Headache Need A Recommended Workshop To Take This On...
Okay soo heres the deal
I got an r34 gt four 2 door awd
I swapped the rb25de to an rb25det neo
Z32 meter
34 gtr manifolds and turbos and front pipe
33 gtr dumps
Stagea S2 tiptrpnic box
Stagea s2 ecu
Stagea s2 wiring loom
Im uaing the loom due to the fact it has the plugs for tiptronic box and the ecu has the auto trans computer built in.
Now heres my dillema since the wiring loom is obviously different to the plugs inside the car theres 2 intotal that dont match up the stagea loom
The car can turn over but whont start due to missing 12 volts to the fuel pump most things work ive had a go at the wiring but ove finnaly faced the fact is beyond my own area of knowledge
Can anyone recomend a workahop who will take this on? None of the auto elecs from where i am moe victoria... Sigh yeah yeah yeah pay it out more and ask me if i wear moccasins .. :) anyway they dont want a bar of it down here and please be helpfull and dont give me the usual line of "why didnt you go rb26 or why didnt you go manual" heard it soo often i juat wanted to make something unique and to distract me away from my battlefield and diablo urges
Anyway any help would be sweet :)
prob easiest way would be to hard wire the pump off the battery to confirm all is OK
then someone can focus on restoring the fuel pump power relay from the main ecu
cant be that hard
any decent jap workshop could do it
chasers / racepace / re customs / dr drift
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
