Don't you just hate it when your cooler pipe is in the way of installing your airbox snorkel
I have a R33 GTST airbox snorkel that's been modified to suit aftermarket cooler kits where normal airbox snorkels don't fit because of the cooler pipe being in the way.
This took ages to custom fabricate, it was a flaming mongrel to do,
when its on the car you cant even tell looks like factory.
Great for those people wanting to run a front mount and want to still use a stock airbox & snorkel so you don't get done by the cops.
Car was making 238 kw at the rear wheels and this snorkel flowed fine
asking $120 Pick up from Taylorslakes Melb. or can post oz wide for $15
You are more than welcome to come try it on your car to see if it clears the cooler pipe. Sale is for airbox snorkel only,
call /sms: 0422756270
Edited by G4orce
  • 3 weeks later...
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
    • That's the one I have in my R32. There isn't a bigger battery that will fit an R32.
    • Not sure what you mean haha. That one doesn't fit mine but when I get sick of my one I'll get a standard one. I just gotta find a way to make it fit cause some shit is in the way.
    • https://www.supercheapauto.com.au/p/century-century-ultra-hi-performance-4wd-battery-ns70x-mf/602477.html MF for Muthaf*kka
