Hey guys im selling my 1994 R33 its maroon, manual, turbo and has 120,000km. The car is very clean and pretty much stock except for exhaust, front mount, intake, stereo, boost gauge and sunroof. it has rego til september and can organise a RWC. I am a mechanic and this car is in perfect condition for its age, i have been using it as my daily for a while now but want to sell ut to buy another rotor.
Contact me on 0425 311 592.
https://www.sau.com.au/forums/topic/401096-1994-r33-gtst/
