Hey everyone, I'm new to all this, but I want to start looking for a skyline (even though I'm not even on my L's) and I want to spend alot of money on it to do it up. Since my dream car has always been a skyline, that's what I want. So I was wondering what would be the best P plate friendly skyline to get, like what are the ups and downs? Thanks guys. :)
https://www.sau.com.au/forums/topic/401105-best-non-turbo-skyline/
V37 is the best N/A skyline atm imo.
Depends on what state you live in, if you are in a state with P-plate car restrictions then doing up an N/A R32-34 is just a waste of money.
V37 is uber hot.
Probably a little out of your price range.
If you go through the forums you will most likely find one answer most common.
Buy a cheap shit box, save your coin, and buy a turbo version when you've got your full license.
However, if you are extremely impatient, buy the one you like the look of most.
After all, when you can't go that fast, its all about looks.
Wouldnt buy a NA skyline to modify...maybe if your interested in suspension, Brakes and Cosmetics. But Motor is a big No NO ! the car is to heavy. But otherwise from my experince with R34 NA they drive nice and feel sturdy ! but dont pack a puch like the Turbo's (8 second 0-100). My advice is if your going to spend $$$ get a S2000 seriously its the way to go if you want speed and fun ! only thing its 2 seater so your mates will give you shit.
Edited by starwarz
if you want to spend a lot of money doing a skyline up then wait till you have your opens and can drive a turbo skyline. doing mods to a NA skyline is a waste of money (especially if you plan on doing performance mods). NA skylines aren't that fast and will get beaten by plenty of other cars out there, if you are thinking you will be able to beat commodores, etc off from the lights
hey mate, you're a bit like myself, although I wanted a 350Z first up until I learned that they are on the P's restricted list. My mate let me drive his R34 GTT and I've pretty much been in love with the R34 since. For beginners, as many people have told me, don't bother getting a Skyline but I ignored them and got myself a 98 R34 25GT. I rekon they are great for starters who wants to lead into tuning it up and things like that. If your not into the later model skylines like the V series, the R34 GT would be the way to go IMO. They cost about $9-14K on average. Picked mine up for $11K.
Get yourself a R34 GT and when you get your fulls, get yourself a GTT or GTR if you have the cash. I too was thinking of doing up my car but it's not worth pouring $5K+ in coilovers, brakes, wheels etc since you can't do anything to increase performance yet.
I'm happy with what I've got and I'm planning to sell the car once I get my fulls. When it's gone, either I get myself a 350 or a GTT or GTR. I suggest you do the same way.
Where abouts are you from in Sydney?
Here's mine:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=390699
Edited by xntrq
Id say a GTS4 R32 or R33 depending what shape you like best,
Keep the revs boiling and use the AWD to your advantage.
End of the day N/A get flamed on here, So go for what you like best.
Dont expect it to be cheap for insurance ect.
Dont bother modding it for power, unless you do a full engine conversion, Even then thats a bit of a headache.
What ever you do, Have fun and drive safe
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
