Manuel, i got top feeds in under stock plenum...it can be done mate and theres a few ways around it..can get 2000cc in there if you want... :thumbsup:
the injectors I used were Xspurt 750s (basically same as IDs under a different brand name) which are 40mm, Its a tight fit but I am pretty sure you could get 48mm ID 1000s in there as well,...rail and reg should only set you back $200ish
Alternatively Deatchwerks do 1000cc side feeds.. cheap too
http://www.deatschwe...rb25det/1993-98
FiveO do 1000cc and 1200cc side feeds. They use new JECS injectors and then they high flow them and flow match them. Cheap prices but have heard good and bad things about them. I'm interested in hearing results if any of you guys have used them as I'm trying to decide on a set of FiveO 1200cc or ID1000's.
Edited by slippylotion
