I have 2 sets of R32 GTR headlights with New Kaixen HID kits. (H1 & H3)
One set recently fitted with the HIDs (H3) on my GTR and One spare set.
$350 for each set of head lights plus postage.
All clips etc are good meaning not cracked or broken. All lenses are not chipped or cracked.
Pics up during the week.
Reason for selling is I just bought New N1 headlights.
Cheers
Richard
  • 3 weeks later...
Ok finally took the second set off my R32 GTR. Alot of requests for Pictures so here goes.
Note: both front left projector headlights have minor crows feet.
So if you want BNIB drop a grand+ for each pair else where.
These are $350 the pair with new Kaixen HID kit. (H1 & H3) or $250 a pair no HID.
First pair are H3
  On 18/06/2012 at 3:56 AM, Sinista32 said:
and some rear shots. All clips etc are in good condition. No breaks, cracks etc
hey Sinista, which set is left:
Foreground or Background set?
Cheers
These ones. They have the HID kit wiring on them. In this set of pics there in the foregraound
post-13786-0-78989900-1339991560_thumb.jpgpost-13786-0-84730700-1339991568_thumb.jpgpost-13786-0-66820800-1339991573_thumb.jpgpost-13786-0-94182600-1339991577_thumb.jpgpost-13786-0-36745600-1339991583_thumb.jpgpost-13786-0-21500500-1339991588_thumb.jpgpost-13786-0-71725200-1339991592_thumb.jpg
  • post-13786-0-20353900-1339991760_thumb.jpg closest to the bottom in this frame
  • 3 months later...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
