1998 Nissan Stagea series 2 RS4 S Dayz edition Silver Factory 5 speed Manual
Excellent condition for age
2nd car owner, 1st owner in Australia
Purchased stagea in September 2007 67,000km
Currently has 198,000kms
Will be sold with Road Worthy Certificate
Registration until September 2012
New Front windscreen
Will be sold with new tyres
Will be sold fully detailed
Non smokers car/non pet owner
Serviced every 5000km full detailed service history
Always ran on high quality oil and fuel (98 ron)
New clutch fitted on the 18/10/11
Factory options
17x7.5 factory RS4 S mags
ABS braking
SRS Airbags Driver and Passenger
Power steering
Aircon and climate control
Power windows
Power mirrors
Cargo blind and cargo barrier
Xenon headlights (adjustable tilt)
Hicas 4 wheel steering
AWD
Factory RS4 S gauges
Full set of series 2 Factory stagea floor mats including rare rear boot mat
Folding split reclining rear seats
Factory flare
Factory Uv cut Glass
Dayz optional parts
Rear skirt Front bar
Side skirts
Carbon fibre dash instrument panel
After market parts
K&N panel filter
Koni shocks front and rear
Nismo lowered springs
GFB bleed valve
Custom made towbar rated at 2000kg with hayman reese square hitch
Auto meter boost gauge
3 inch stainless front pipe
Split Fire coil packs
Tinted front windows
Pioneer head unit
2wd switch
Alarm and immobiliser
Blitz turbo timer
$11,500 o.n.o
Phone Stuart on 0418307477 after 6.30pm weekdays and anytime weekends
  • 4 weeks later...
  • 3 weeks later...
New tyres have been fitted with 4 wheel steering alignment on 7/7/2012 at 202,500km
Heres a picture of the engine bay, the shock towers had very minimal rust coming through and have been repared but in undercoat.
Price Drop $10,300
  • 4 weeks later...
  • 1 month later...
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
