Hi guys
Hoping someone can shed some light on this. I replaced my battery today and now i have beeping noise coming from my driver's footwell. The beeps quicken when i have the ignition on or turn the car on.
I tried searching here and G35 forums with limited success.
I tried holding down the buttons on the keyfob for 3-4 secs, couldnt get the horn to sound or lights to flash (had read that this can 'reset' beep noises in cabin)
Have also inspected each of the fuses in the driver's footwell, all are good.
Any ideas from anyone?
Cheers
Mat
Edited by mattyray
hmm sorry I can't be of more help but since nobody else has chimed in so far...
I take it no warning lights on the dash suddenly lighting up with the beep?
You could try resetting the ECU & see if that stops the beeping.
hope you get it sorted soon
Thanks Yo-yo, yeah no warning lights, car seems to operate normally.
Whats the easiest way to reset the ECU? I've read theres a few ways and not all of them apparently work!?
Cheers
^^ does that still work?? I thought resetting the ECU by disconnecting the power was something that hasn't worked since the mid 1990s? everything is stored in flashRAM now isn't it?
i put a Z tube on my 2003 A/T on Saturday and the final instruction was to disconnect the negative side of the battery to reset the ECU. It worked. ;)
mattyray did it stop beeping :huh:
Nope, doesnt seem to work. Reconnected battery this arvo and the beep is still there.
Too scared to drive it around with a constant beeping at me.....havent found anywhere that can look at it for at least a week!?
grrrrrr
Yeah, thats exactly what i asked for from 3 Nissan dealerships, earliest i could get in was 6th of June!
Cheers for the advice anyways guys.
Happy to hear from anyone else who has encountered similar issues.
Edited by mattyray
6th of June - they've got to be pulling your leg! Probably giving you crap service because it's an import.
You could try a Repco mechanic or some other private workshop. Many of them have a comprehensive array of diagnostic devices.
Heck, I could probably post you my Cipher cable to get there before then.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
