Hey, i have a 93' R33 and first of all i would like to say that this car bloody ROCKS!!
However, I'm a little concered about the petrol usage.....i know that they use a lot of gas relative to other (naturally aspirated) cars but at the moment I'm getting just under 300K's for a full tank when driving it fairly quietly....is this normal??
https://www.sau.com.au/forums/topic/40115-r33-high-petrol-usage/
From your post comparing yours to other NA cars, I'm assuming yours is a NA? That does sound a little odd...
I can imagine a turbo with some mods (and not much tuning) getting the figure down to this, but not a NA. My GTS-T (stock) currently runs around 400-420km/tank city driving, 620-650km country. (220km lead foot.)
So I'm sure with some tuning you can get your economy back up.
From your 1st post seems that you have just recently acquire your R33 and still "enjoying" the newfound pleasure trip to power zone.... which means you're likely to drive your R33 with a heavier right foot, right? It happened to me too and yes, fuel consumption can be high. It all depends how heavy your right foot is. Try to stay off boost most of the time and you'll see that RB25DET fuel consumption is similar to most other NA 6-cyl cars.
For a comparison freeway consumption should be around 10L/100km, while city consumption (depends on traffic) can be around 12-13L/100km. May jump to 15-16L/100km if you drive it "enthusiastly". If it's modified (higher than stock boost, aftermarket ecu, etc) then it can get higher.
dont worry, its normal!
as a guide, over one weekend i did lots of open road driving, (not all freeway, mostly high speed twisty roads) and calculated 9.5L/100kms
in reasonably heavy city driving, most of the time consumption was between 16-18L/100kms.
btw, dont take the fuel gauge as a guide to when it is empty, u can only accurately measure consumption by filling up, resetting the trip meter, then next time u fill up see how much goes in and work it out with the distance travelled.
you could always try resetting the ECU.
disconnect the battery (in the boot under the parcel shelf), and either put your foot on the brake or leave the car overnight (to drain power stored around the car).
Reconnect the battery and drive 'Granny Style'. for the first 1-2 tanks of fuel.
The ECU starts on a base map, but then adapts to your driving style - the lighter you are on the gas, the better the fuel consumption will be!
NOTE: You'll have to reset your clock and radio settings, but my R33 GTSt gets about 400-450km daily driven (city and highway) out of a tank. My only Mod is a cat back exhaust (for now).
lol i get about 200k's per tank, but ppl tell me i drive it 100% on boost, :confused: dunno what they are talking about... /me runs
100% on boost? oooooo I would like to see it.. ;) Could it be that these ppl is saying that you hit boost all the time? :)
Hrmm... dang.. From memory. I get close to 300ks per tank and tats hammering it every now and then (well. .often). Tho mine is a R34 GTT tho and even this car is costing me a fortune to run.... Hell fun tho and the wastegate noise is awesome. :P
LOL, well u know what i mean, perhaps 100% throttle was a better thing to say :evil:
So far my car is at 1/4 tank left and 320 kms(haven't had it long)...roughly 15L/100Kms and there has been some "spirited" driving and a lot of city driving as well. Not too bad I guess.
I just did 360km/55 litres which includes a full on 50-60km road tune and I hammer it quite often with a single way trip of 12km. Not the best for economy.
I think 400km is doable with some care. My motor also runs lowish compression (8.5:1 maybe).
T.
I usually get around 350-400km out of 55L, and that's with city driving, a PowerFC still on the base map (so sub 10.0:1 AFR's when booted), a button clutch (so more revs and a heavier throttle on takeoff) and a T3/4 turbo.
When the car was stock minus pod, exhaust and 10psi, I'd regularly see 550km from 55L. On one trip (Ipswich to Rainbow Beach and back, plus a bit of driving in between, stock minus a quiet 3" exhaust) I managed over 900km on 54L of premium, or less than 6L/100km :rant: I made it to Rainbow Beach on less than 1/3 of a tank. I sat on 110km/h pretty much the whole way, and being NYE of 2000, I drove with a very light foot. My car is MUCH more efficient at 110 than at 100, IMHO it would've done at least 70 or 80km less on that tank at 100km/h.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
