Hey, i have a 93' R33 and first of all i would like to say that this car bloody ROCKS!!
However, I'm a little concered about the petrol usage.....i know that they use a lot of gas relative to other (naturally aspirated) cars but at the moment I'm getting just under 300K's for a full tank when driving it fairly quietly....is this normal??
https://www.sau.com.au/forums/topic/40115-r33-high-petrol-usage/
From your post comparing yours to other NA cars, I'm assuming yours is a NA? That does sound a little odd...
I can imagine a turbo with some mods (and not much tuning) getting the figure down to this, but not a NA. My GTS-T (stock) currently runs around 400-420km/tank city driving, 620-650km country. (220km lead foot.)
So I'm sure with some tuning you can get your economy back up.
From your 1st post seems that you have just recently acquire your R33 and still "enjoying" the newfound pleasure trip to power zone.... which means you're likely to drive your R33 with a heavier right foot, right? It happened to me too and yes, fuel consumption can be high. It all depends how heavy your right foot is. Try to stay off boost most of the time and you'll see that RB25DET fuel consumption is similar to most other NA 6-cyl cars.
For a comparison freeway consumption should be around 10L/100km, while city consumption (depends on traffic) can be around 12-13L/100km. May jump to 15-16L/100km if you drive it "enthusiastly". If it's modified (higher than stock boost, aftermarket ecu, etc) then it can get higher.
dont worry, its normal!
as a guide, over one weekend i did lots of open road driving, (not all freeway, mostly high speed twisty roads) and calculated 9.5L/100kms
in reasonably heavy city driving, most of the time consumption was between 16-18L/100kms.
btw, dont take the fuel gauge as a guide to when it is empty, u can only accurately measure consumption by filling up, resetting the trip meter, then next time u fill up see how much goes in and work it out with the distance travelled.
you could always try resetting the ECU.
disconnect the battery (in the boot under the parcel shelf), and either put your foot on the brake or leave the car overnight (to drain power stored around the car).
Reconnect the battery and drive 'Granny Style'. for the first 1-2 tanks of fuel.
The ECU starts on a base map, but then adapts to your driving style - the lighter you are on the gas, the better the fuel consumption will be!
NOTE: You'll have to reset your clock and radio settings, but my R33 GTSt gets about 400-450km daily driven (city and highway) out of a tank. My only Mod is a cat back exhaust (for now).
lol i get about 200k's per tank, but ppl tell me i drive it 100% on boost, :confused: dunno what they are talking about... /me runs
100% on boost? oooooo I would like to see it.. ;) Could it be that these ppl is saying that you hit boost all the time? :)
Hrmm... dang.. From memory. I get close to 300ks per tank and tats hammering it every now and then (well. .often). Tho mine is a R34 GTT tho and even this car is costing me a fortune to run.... Hell fun tho and the wastegate noise is awesome. :P
LOL, well u know what i mean, perhaps 100% throttle was a better thing to say :evil:
So far my car is at 1/4 tank left and 320 kms(haven't had it long)...roughly 15L/100Kms and there has been some "spirited" driving and a lot of city driving as well. Not too bad I guess.
I just did 360km/55 litres which includes a full on 50-60km road tune and I hammer it quite often with a single way trip of 12km. Not the best for economy.
I think 400km is doable with some care. My motor also runs lowish compression (8.5:1 maybe).
T.
I usually get around 350-400km out of 55L, and that's with city driving, a PowerFC still on the base map (so sub 10.0:1 AFR's when booted), a button clutch (so more revs and a heavier throttle on takeoff) and a T3/4 turbo.
When the car was stock minus pod, exhaust and 10psi, I'd regularly see 550km from 55L. On one trip (Ipswich to Rainbow Beach and back, plus a bit of driving in between, stock minus a quiet 3" exhaust) I managed over 900km on 54L of premium, or less than 6L/100km :rant: I made it to Rainbow Beach on less than 1/3 of a tank. I sat on 110km/h pretty much the whole way, and being NYE of 2000, I drove with a very light foot. My car is MUCH more efficient at 110 than at 100, IMHO it would've done at least 70 or 80km less on that tank at 100km/h.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
