i have a built rb26 still at the builders but is ment to be finished in a 2 weeks
i have lost intrest in this project and dont have the funds to finish it they way i wont it
and want to buy a house
specs intail
N1 block machend and decked and oil restrictor $3500
hks cams 264 and 272 10mm lift $1200
tomei oversize inlet valves $350
supertech oversize exh valves $250
tomei cam studs $300
ferrea duel valve springs with titanium retaines $1300
total seal rings gapless rings $600
tomei valve guides $700
hks valve stem seals $250
je 86.5mm pistons $900
arp head bolts $300
arp main studs $300
manley rods with arp studs$800
os giken cam gears $300
greddy clear timing cover $150
acl bearings $300
gates timing belt $120
nsk timing belt tensioner and idler $200
N1 water pump $250
tomei 1.5 head gasket exhaust and inlet gaskets $600
rear head dain and braided line $300
custom 8lt sump gated with extrnal pick up $1400
moroso extrnal oil pump $900
ross balance with tooth gear for pump and belt $100
standard oil pump with gears out new seals and gaskets $220
n1 crank balances and grub screwed $1000
ported and polished head and maching to fit cams $2500
sard 1000cc injectors $1000
greddy fuel rail $300
apexi power fc de-jetro and controller $1200
also have a trust td05 18g high mount twin turbos set up
with trust 50mm gate all braided lines, dump pipes and hot pipes
done little work since rebuild $4500
standard inlet manifold
welded dash 12 into rocker covers
not one expense spared other then inlet mainfod which was next on the list
built to run 30psi all day
that comes to $26050 plus anything i have forgotten which i think there will be
all work done lewis engines
not sure what to ask for this as it has cost a lot of money
$21000ono
located adel hills sa
https://www.sau.com.au/forums/topic/401161-built-rb26-n1-block-and-td05-turbos/
This engine is built fine mate a lot of time and research have gone into this motor.
Also if u got nothing good to say dont post it. Cheers
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
