i have a built rb26 still at the builders but is ment to be finished in a 2 weeks
i have lost intrest in this project and dont have the funds to finish it they way i wont it
and want to buy a house
specs intail
N1 block machend and decked and oil restrictor $3500
hks cams 264 and 272 10mm lift $1200
tomei oversize inlet valves $350
supertech oversize exh valves $250
tomei cam studs $300
ferrea duel valve springs with titanium retaines $1300
total seal rings gapless rings $600
tomei valve guides $700
hks valve stem seals $250
je 86.5mm pistons $900
arp head bolts $300
arp main studs $300
manley rods with arp studs$800
os giken cam gears $300
greddy clear timing cover $150
acl bearings $300
gates timing belt $120
nsk timing belt tensioner and idler $200
N1 water pump $250
tomei 1.5 head gasket exhaust and inlet gaskets $600
rear head dain and braided line $300
custom 8lt sump gated with extrnal pick up $1400
moroso extrnal oil pump $900
ross balance with tooth gear for pump and belt $100
standard oil pump with gears out new seals and gaskets $220
n1 crank balances and grub screwed $1000
ported and polished head and maching to fit cams $2500
sard 1000cc injectors $1000
greddy fuel rail $300
apexi power fc de-jetro and controller $1200
also have a trust td05 18g high mount twin turbos set up
with trust 50mm gate all braided lines, dump pipes and hot pipes
done little work since rebuild $4500
standard inlet manifold
welded dash 12 into rocker covers
not one expense spared other then inlet mainfod which was next on the list
built to run 30psi all day
that comes to $26050 plus anything i have forgotten which i think there will be
all work done lewis engines
not sure what to ask for this as it has cost a lot of money
$21000ono
located adel hills sa
https://www.sau.com.au/forums/topic/401161-built-rb26-n1-block-and-td05-turbos/
This engine is built fine mate a lot of time and research have gone into this motor.
Also if u got nothing good to say dont post it. Cheers
